i30 N Steering Noise / Creaking
iiNNEX
553
484
Surrey, UK
Who says hyundai don't do the same thing. Seems a waste of garage time to dismantle a car when it can be reached.
Because Hyundai follow a TSB which tells them to take the rack out, take it apart and grease some parts inside.
The lubrication we are talking about here is not the same thing.
Reactions: _Emma and Danloki
Davo01
416
533
South Australia
Mine was a creak, and it was “cured” by adjusting a heatshield near the steering column. Not silicone or greasing the rack. I watched the tech do it.
A steering knock is likely to be the rack.
Davo01
416
533
South Australia
Constant Creak is either heatshield needs minor adjustment or a bit of silicone spray to lubricate the rubber bung area in tbe footwell/firewall.
A knock is the rack. TSB says to grease and then replace if not fixed.
Confirmed by my Hyundai tech who fixed my heatshield and his personal N heatshield and knocking rack.
Reactions: BillTheButcher
BillTheButcher
Sep 9, 2019
135
134
So there doesn't seem to be any one single fix for this, do we know exactly what part is faulty?
As far as the information on the worksheet goes, they've only replaced one part on my car: the steering rack. In the few miles that I've done since then, I haven't heard any knocking or creaking. Of course, it's possible that they adjusted rather than replaced another part that's fixed the creaking.
Dingo67
4
10
Canberra ACT Australia
Fastback - Australia. Had the drummy metallic creaking noise start from a gradual occurrence with ~300km on odo, increasing to being continuous at approx 600km. Noise would occur with even the slightest steering wheel movement at all speeds, and also when front end was twisting going over driveways. Loud and invasive.
Tried the lube spray into the steering column housing at the firewall as mentioned previously in this thread - no improvement.
Local mechanic investigated (not Hyundai) and showed me on the lift - with steering wheel movement a relatively large heat shield located under the engine / steering components would twist making the noise. They weren't sure about adjusting the heat shield. (when the heat shield fix was mentioned earlier in this thread, I pictured a vertical circular type heat shield around the steering column running from the firewall to the rack. It is actually a flat shield probably about 40 cm across (IIRC) and maybe 30cm front to back (wish I had taken a photo) - it sits under the rack / engine mid car about in line with the pedals. it is probably about 5mm thick, it had quite a twist when moving).
Took it to Hyundai and explained the heat shield movement - within 3 hours they had adjusted this heat shield, and a second heat shield somewhere around the exhaust components - result: no more creaking. Driving daily for a week since fixed. There is an occasional creak (quiet, not invasive) but only with large steering wheel movements when stationary or slow speed (i.e parking); still absolutely nothing at driving speeds.
So much more enjoyable now without the noise.
No mention of lubrication within the rack or possible rack replacement.
Davo01
416
533
South Australia
That’s great news - taking it to an independent mechanic just for a look was genius:)
I saw the tech use a small pry bar to adjust mine - now I know why, sounds quite a substantial bit of metal.
I share your feeling of enjoyment once fixed. Such a relief, the silence is indeed golden.
So before any of you just roll over and let them replace the rack: unless there is a knock sound it is NOT the rack. Take note of Dingo67’s cleverness: pay for an inspection elsewhere. You don’t want the subframe dropped for no reason. Sure they *can* be disassembled and put back, but are not intended to be ;-)
N-Soju
6
14
Melbourne Victoria
Needs different grease in the bearings had mine done under warranty, seems to have cured it
Hay guys,
My fastback have exactly the same problem described, I tool it back to the dealer not long after newly purchased from Melbourne dealer, first time they say it could be the whole steering column needs replace, had to wait for dealer to schedule me back, took it back and they didn't change anything or maybe fiddling with some parts, drove out the dealer seems fine, then same issue happens again after a day or two, took it back and they've replace a bigger washer "as been told" after few days ....again same issue reappears. so 3 attempts and the dealer still could not fix the problem. I'm not sure they are trying to take a short cut trying to fix the problem or they are just not sure how to fix it.. sighhhh,,
GazmaN
Oct 28, 2018
1,716
2,863
Darwin, Australia
Hay guys,
You're amost spoiled for choice in Melbourne so maybe you should consider taking it to another dealer. Tell them the dealer you bought it from can't seem to fix it and offer them your future business if they can solve your issue.
ialexpw
7
United Kingdom
Had my i30 around two weeks now from new and I've started hearing a creaking noise with a bit of movement from my wheel whether moving or stationary, could someone that's had this issue tell me if it's a similar noise in the video? (might have to turn it up a bit to hear it)
Video
Jajodu
704
633
Bishops Stortford
Video
Silicon grease on the base of the steering column inside the car and also underneath. Spray silicon is best.
BillTheButcher
Sep 9, 2019
135
134
Video
Sounds exactly like mine did. I also had a knocking sound when approaching full lock at parking speeds. Hyundai fitted a new steering rack (they tried greasing the steering rack/column first but it made no difference) which sorted it.
mikeo
Jan 4, 2020
180
133
SW Scotland
Video
I've just noticed this exact noise at low speed maneuvering today. Might have been there for a while, usually have the radio on, so maybe not noticed it before. Think I'll have a play around with it tomorrow and then pick up a can of silicon spray if the noise is definitely there. Always something with cars!
Jajodu
704
633
Bishops Stortford
Look at the picture in post #19
Reactions: mikeo
MrLaney
2
2
South Wales
Took mine to Hyundai yesterday, confirmed its a known issue and they told me they had to remove front wheels, disconnect the rack to lubricate the bearing and then use some special packing washers to move the rubber boot shown before to stop that catching too. Low and behold, the noise is all gone now and it cost absolutely nothing apart from my time lol
