Technical Specifications:
Brand: Hyundai
Model: i30
Generation: i30 III
Modification (Engine): N 2.0 T-GDI (275 PS) (Performance variant)
Doors: 5
Seats: 5
Coupe type: Hatchback/Fastback
Power: 275 PS/6000 rpm.
Maximum speed: 250 km/h
Acceleration (0-100 km/h): 6.1 sec
Year of production: Q4 2017 - .
Colour availability:
Polar White (PYW Solid)
Clean Slate (UB2 Metallic) (Discontinued Sep 2018)
Micron Grey (Z3G Metallic) (Discontinued Nov 2020)
Dark Knight (YG7 Metallic) (Nov 2020+)
Phantom Black (PAE Mineral Effect)
Performance Blue (XFB Solid)
Engine Red (JHR Solid)
Shadow Grey (TKG Solid) (MY19 Fastback, MY20 Hatchback)
Red lower trim colour code:
NRR Passion Red
Length (Fastback): 4335 mm (4455mm).
Width: 1795 mm.
Height (Fastback): 1451 - 1447 mm (1419mm).
Weight: ~1584 kg (full tank, 75 kg driver)
Wheelbase: 2650 mm.
Ride height: 136-132 mm.
Front overhang: 905 mm.
Rear overhang (Fastback): 780 mm (900 mm).
Min/Max volume of Luggage in trunk (Fastback): 395 L / 1301 L (450 L / 1351 L)
Head room front/rear: 994 mm / 977 mm
Leg room front/rear: 1,073 mm / 883 mm
Shoulder room front/rear: 1,427 mm / 1,406 mm
Model Engine: THETA II series GDI
Engine construction: aluminium block & head
Position of engine: Front, transversely
Engine displacement: 1998 cm3
Charge system Pre-FL: Twin-Scroll Turbo 1.2 bar (MHI 28231-2GTB1/C1/D0)
Charge system FL: Twin-Scroll Turbo 1.2 bar (MHI 28231-2GTE0)
Torque: 353 Nm (378 with overboost) /1450-4500 rpm.
Specific torque: 176.68 Nm/litre
Specific output: 135.9 bhp/litre
Power-to-weight ratio: 189.99 bhp/tonne
Weight-to-power ratio: 11.79 lb/bhp
Valvetrain: DOHC, E-CVVT
Position of cylinders: Inline
Number of cylinders: 4
Firing order: 1-3-4-2
Cylinder Bore: 86 mm.
Piston Stroke: 86 mm.
Crankshaft bearings: 5
Compression ratio: 9.5
Number of valves/cylinder: 4
Fuel System: Direct injection
Fuel Type: Petrol (Gasoline)
Fuel tank volume: 50 L
Fuel consumption NEFZ (L/100km): 9.7L urban / 5.7L extra urban / 7.1L combined
Fuel consumption WLTP (L/100km): 10.2L urban / 6.3L extra urban / 7.7L combined
Fuel consumption NEFZ (km/litre): 10.3km urban / 17.5km extra-urban / 14.1km combined
Fuel consumption WLTP (km/litre): 9.3km urban / 15.9km extra-urban / 13.0km combined
Carbon dioxide emissions: MY18 (163.0 g/km), MY19+ (178.0 g/km - NEFZ / 188.0g/km - WLTP)
VED band (UK): G
CO2 Effizienz (DE): MY18 (D), MY19 (E), MY20 (E)
Emission standard: MY18 (Euro 6c), MY19 (Euro 6d-Temp), MY20 (Euro 6d-Temp-EVAP)
Differentiation between model years:
MY18 - round fuel door
MY19 - square fuel door
MY20 - square fuel door + silver rear silencer cover
Noise levels:
Stationary: MY18 (109dBA), MY19-20 (91dBA) (manual)
Driving: MY18 (72dBA), MY19-20 (71dBA) (manual)
Drag coefficient:
Fastback: 0.297
Hatchback: 0.320
Engine lubricant oil capacity: 4.8 L with filter change
Engine coolant capacity: 8.5 L
Transmission oil capacity: 1.9 L
Battery capacity (Ah): 70
Drive wheel: Front wheel drive
Number of gears: 6
Gear ratios (overall):
1. 3.083 (13.36)
2. 1.931 (8.37)
3. 1.272 (5.51)
4. 0.957 (4.15)
5. 0.771 (3.34)
6. 0.641 (2.78)
R. 3.588
Top gear value theor. (km/h):
1. 59
2. 95
3. 144
4. 191
5. 237
6. 285
Front suspension: Independent type McPherson
Rear suspension: Multi-link independent
Brake system: Dual-diagonal, split circuit, power assisted with Electronic Brakeforce Distribution (EBD) and Brake Assist System (BAS)
Front brakes: Ventilated discs
Front brake diameter: 345 mm x 30 mm
Rear brakes: Ventilated discs
Rear brake diameter: 314 mm x 20 mm
Steering type: Steering rack
Power steering: Electric Steering R-MDPS
Minimum turning circle (turning diameter): 11.6 m
Steering wheel lock to lock turns: 2.57
Turning circle btw. curbs: 11.6 m
Differential (front): Electronically controlled mechanical Limited Slip Differential (E-LSD)
Payload (kg): ~470 - 550 kg
Max. weight: ~1950 kg
Max tow weight braked/unbraked: ~1,600 / 700 kg
Tire size: 225/40 R18; 235/35 R19
Wheel size:
7,5J R18 ET: 53.0 LK: 5x114,3 CB: 67,1 (~12 kg)
8,0J R19 ET: 55.0 LK: 5x114,3 CB: 67,1 (~13,1 kg)
Wheel bolts: M12x1.5
Wheel lug nuts socket size: 21 mm
Wheel bolts torque settings: 79-94 lb·ft or 107-127 nm
Front seat weight 30.1kg / 66.4lbs
Rear seat weight 9kg / 19.8lbs
Wheel Alignment / Geometry
