Wrong - in Poland it cost about 80 złotych = 17 euro but in Germany 10-15 euro for sticker and 70-80 euro for emission test.Sticker you can buy on any Dekra station in Germany. Cost about 10-15€ I don't remember.
What’s happened?? I was watching his story waiting for the resultsNo problems.... It is a disaster.
you'd need something like this: https://n-cars.net/forums/threads/bu11ets-melody.3147/page-16#post-102111will cut the oem filter box to provide more airflow because Markus told me that the oem box inlet is a limiter too even with my velossa tech snorkel.
I saw that part in Markus workshop - I'm thinking about 90-120mm hole in box bottom with someking od computer fan cover.you'd need something like this: https://n-cars.net/forums/threads/bu11ets-melody.3147/page-16#post-102111
or a different airbox design![]()
Yep, I sent it to him after he asked for one. In general just cutting the airbox will help the engine get more air, disadvantage to just cutting a hole is that the engine can then pull warm air. But should be sufficient for testing its effect.I saw that part in Markus workshop
does your dyno have sufficient air turbines to push air into the intake? Not talking the small ones as Markus has but way bigger ones. Otherwise you will not see a big difference either way.before cutting the intake box I will do dyno test with closed box and with open - to see any differences. If it will be none or minimal - oem box will stay without cutting the hole.
You can cover it if you want, but it should not make a difference. Your exhaust manifold also is not covered and has similar temps under load.Any suggestions ? Try to cover it or not ?
I didn't see Markus dyno but I think it is the same MAHA with that front smaller fan in front of the car grill.does your dyno have sufficient air turbines to push air into the intake? Not talking the small ones as Markus has but way bigger ones. Otherwise you will not see a big difference either way.
Markus says a more air is needed since he is measuring the negative pressure build up in the airpipe. It's a recommendation to make life easier for the turbo - it does not necessarily has to have a big impact to the power figures. I'd cut it open either way just so you don't punish the turbo as hard.
yep, Markus has a similar fan setup.I didn't see Markus dyno but I think it is the same MAHA with that front smaller fan in front of the car grill.
Here are small pictures from the internet of mine dyno point:
View attachment 20117View attachment 20118
If we talk about downpipe - so better to left it like that if temperature is not a problem.
