I managed to install my rear camera today.
Starting with disconnecting the battery (just in case)
and feeding the wire behind the passenger airbag in the A-pillar.
Then feeding the wire to the bottom of the doorsill, and fishing it true the plastic cover of the B-pillar.
I was planning to use an electrical wire as guide, but i had better luck just pushing the dashcam-wire by itself,
(with allot of patients and the help of some tweezers)
The last step was probably easier then I expected.
Feeding the wire back up again, where the window and roof liner meet, you can just pry a gap with your fingers and push the cable in.
When your this far, you just loosen the bootsill,
remove the plastic cover off the boot which comes off very easy,
and loosen the rubber cable guide.
Than feed the cable true, and your all done.
The only part where I screwed up is by loosening the plastic cover of the bottom of the front door.
I don't know why but it just wouldn't click back into place, not even after applying some force,
which was the case with the plastic airbag cover of the side airbag.
So now there is a little gap between the 2 plastics.
The step is not needed, I did it when i was looking for some way to route the cable.
All other plastic and fabric covers snap back into place, except this one, so if anyone has a solution.
It would be much appreciated.
I own a Viofo A129 duo, and my cable was long enough.
But be sure to check your length when starting.
Sadly
Mightymoo wasn't so fortunate.
