Hi guys,
I have a question about installing a radar warner, it is basically the same as a dash cam but uses 12V and will be installed at the drivers sun visor. I used this thread to install it but I am stuck now and don´t know what the problem with my setup is. I will post pictures below so you can see it, but basically, I used the same fuse to take the 12V and then took one strip of the 12V cable to the warner and put it on there and the other one I used some metal and attached it to it. I hope it gets clearer with the photos and I hope someone finds my fault!
THANK YOU!
