i think that depends on the cable your cam is delivered with. in most cases lifting the panel will be enough, but with thicker cables you might need to remove the panel.
Reactions: DanFez
Yes it's easy.. just pull away the rubber trim round the top and side of door and firmly pull the A post trim away from the top... No need to remove the bottom end... Feed the wire underneath the front head lining and down the A post UNDERNEATH the airbag.
Remove the fuse box side panel... and front access panel... I also removed the complete front panel... Just three screws hold it... Two under the side panel and one underneath at the other end...and pull it off... Makes the job a lot more accessible.
Reactions: DanFez
I bought the Nextbase hardwire kit but it doesn't contain a Micro2 fuse holder. Worth noting if you have a Nextbase cam and are planning on buying the kit to hardwire into an i30N. I called Nextbase and they offered to send me out a Micro2 holder and fuse for the dashcam at no cost.
Reactions: DanFez and BadShadd
I managed to push the wire under the edge of the trim with a trim tool so no need to remove it. Just had to peel a little bit of the rubber away where the dash edge meets the door rubber.
Thanks to the OP @DanFez for the guide.
Reactions: DanFez
As I said, once the seal is off, just pull on the A-pillar trim and route underneath the airbag.
Once this is complete, you can clip the A-pillar trim back on.
Next to the side of the dash board.
IGNORE THE MESS :/
This trim just unclips, either use your fingernails, or a trim removal tool to take this cover off.
As you can see there are many bolts which you could use as an earth, ive gone for a 13mm bolt which goes directly into the chassis.
Now the fun part, locate the spare 10amp fuse on the right hand side of the fusebox - I have tested this with a multi-meter and this is an ignition live, meaning this will only turn on when your ignition is on.
You will need a piggyback micro2 fuse holder which looks like so..
Take out the original 10amp fuse and put this in the slot closest to the prongs and ive just used a 5amp micro2 fuse to keep the dash cam safe.
One this has been put in, test the camera to make sure it turns on with the ignition and jobs a goodun!
Tools Needed:
Wire Strippers/Pliers
Crimpers (Can use pliers if not)
Trim Removal Tool
20 minutes of your time.
EASY PEASY -
3/10 on the difficulty scale.
Which slot did you choose in the end
Genuinely just noticed that, may mess with my OCD slightly.. damn.
It doesn’t really matter that they are upside down, must have been how they installed at the factory, or on the alarm installation.
dam right not looked at mine but they will all be the same way before i even start lol, while your here the negative from the wiring was it the black bolt in the pic?
Nice guide Dan very helpfull.
I went to install my Cam today, however didn't realize how hard it is to find Micro Blade 2 Fuse Taps in stores. I've tried all the Auto Elec places.
Seems they sell them but not in the Blade 2 size.
Sure there's other ways around it but I do like the Tap idea.
I've manage to find some on Ebay but really wanted to get the install done today. Ah well
Reactions: DanFez
Fuming took all the trim off, all nice and neat went to terminate in the fuse box and the fuse adaptor turned out to be one size to big, put all back together and ordered a micro2 fuse holder!
Reactions: DanFez
Thanks for the guide, going to attempt this weekend as I'm sick of the sat nav cable flapping about. Couple of questions:
1) Are there any special techniques for getting the door seals out and in without damaging them?
2) My camera has a motion detection standby mode so will be good to keep it powered at all times, the hardwire kit has voltage detection so will cut out after the car batter drops below 11.6v which seems a bit low to me. Anyone think this is a bad idea?
Reactions: DanFez
11.6v should be OK for summer although have mine set at 12V... .the other option being 12.5 v on mine.
Start by pulling the rubber away at the bottom of A post door radius... And pinch the channel tight in the rubber before refitting it.
Thanks for the guide got it installed with no problems.
I pulled on the top of the A Piller to unclip the first clip, made it easier to carefully pass the wire under the air bag. A set of trim tools made it simple.
Attached some additional pictures in case it helps anyone
