You're welcome. :) A 3" downpipe is what you need and if you're not wanting to spend a large amount, try the X-Force Downpipe or here;
Won't allow the use of the OEM heat shields but you can utilize a turbo blanket and some adhesive back heat shielding on the firewall to compensate.
i30N X-Force Downpipe;
Whell I need to find something in EU because these one is not shipping to EU :(
Try them direct instead of thru eBay. If you need help in acquiring one, just ask.👍
PROSPORT Mini Cat O2 Sensor CEL FIX (90°) to insure no CEL from the new downpipe with a 200 Cell Racing Cat. Sometimes it happens, despite an O2 Extender or use of a cat.
Seen this utilized in South Korea and I'm checking on it's adaptation. It does fit the Veloster and if it fits the VN it will be a less expensive Big Brake Kit for the VN. It's a Cadillac CTS V conversion. Just have to verify the fitment.
Reactions: r_anderson96
Reactions: MrDeeJay and Mr. N
ECON5 Piggyback tuner;
Looks very familiar to the SXTH Element Unit manufactured in South Korea (Pross Unit)
Ultra Racing 2-Point Front Lower Bar ;
Ultra Racing 2-Point Rear Lower Bar;
https://www.ebay.com/itm/Ultra-Raci...021987?hash=item4b87b03fa3:g:0QEAAOSwWBJfxax0
Ultra Racing 2-Point Front Strut Bar
Ultra Racing Rear Sway Bar 20mm
Lightweight Underdrive Water Pump Pulley for the 2019+ Veloster N on order.
Pulley weighs about 170 grams, or about 0.37 lb considerably less that the OEM pulley. Utilizes the OEM belt and tensioner and in dark gray titanium.
Red-
Did you see the pulleys from nonstoptuning.com? They are not underdrive, pretty reasonably priced though?
Been awhile since I have been on here. We partnered with NKLAB in S.K., who sells the ECON5 unit, to create the Rev6. The ECON5 is the global market unit, and the Rev6 is the USDM unit. As partners we have continued to add new features to both versions, both hardware and software. The link you posted is actually from a vendor in the Netherlands (supplied by the ECON5 team). We have a ton of new stuff we are working on for 2021 and are very excited to share details soon.
To clarify in regards to your comment: "...manufactured in South Korea (Pross Unit)", we are not affiliated with Pross in any way, nor do they manufacture any products for us.
I'm fully aware of the ECON5 and its origin and it's sale in the Netherlands. And yes it was purposeful because it's the same unit barring a few slight differences.
My comments were direct towards your future response;
We've already taken covers off both units and compared the Rev6 and the Lap3 internal components. The internal components of the Rev6 mirror the internal and closely resemble those of the Lap3 (pross unit). Care to explain?
