Please let us know if it fits without any trimming! Been going between this and the SXTH intercooler. I know SXTHs fits without any modifications (it requires modification) so I'm excited to see how this addition is for you?
There will be no trimming for it to fit.
The SXTH FMIC requires the fitment of their support, and it won't work without it, Theirs completely eliminates the federally mandated NHTSA, (5 mph, low speed, impact bumper), as I specified above. The
Forge Motorsports FMIC retains it. This is just one of the reasons I didn't opt for it.
You might get away with it in a state that doesn't require and annual inspection but it's part of the federal and state safety equipment requirements. Also, it's part of the OEM Hyundai safety equipment, for the car to meet NHTSA regulations to be sold in the US.
It's an additional support structure for the;
"front end module, carrier assembly and subframe."
If you start modifying the basic
front sub frame structure, you lose some front end rigidity. This subframe supports the front suspension components as well. Hyundai designed it everything for a purpose. I'm not going to start modifying it either. No problem with making it stronger but not at the cost of making it lighter and weaker. If I want to make it lighter, I'll use a hole saw cut symmetrical holes and still maintain the same structure integrity and rigidity.
I'm suspect of their cross member. It's not a carrier like the OEM designed unit, capable of sustaining low impact hits, as it doesn't have the absorbers built in. It's not going to maintaining the same OEM structural integrity or rigidity IMO. Not going to cause a problem, to upgrade a part.
