Replaced the clutch on my PFL i30N last month as the original had started to slip.
After much research and help from forum members I decided to get the RTS Organic clutch from MTTuning. Markus was very helpful and explained the proper procedure to bleed the fluid (not as simple as I thought).
I’ve now put 1000km on the clutch and can give the review that I was looking for but didn’t find when researching.
Pros, compared to OEM clutch:
- Can handle more power (Markus says up to 550-600nm).
- Much cheaper than OEM. €550 compared to €950.
Cons, compared to OEM:
- Doesn’t look as well build as oem. The metal is thinner and the overall feel is cheaper.
- Doesn’t have a self-regulating spring (don’t know the proper name). In essence, it doesn’t adjust the bite point of the pedal so it’s always the same as the clutch ages. It starts from very low and goes up with time. Personally, I prefer it this way.
- Clutch pedal is a bit heavier now. Still completely usable in traffic.
All in all, I’m happy with the new clutch. Hopefully it lasts longer than the OEM clutch which started slipping at 75k km (stock car).
Here are some photos from the install:
