Should not be ticking at all. Sounds like a flywheel issue to me. Here’s a video of one ticking: https://drive.google.com/file/d/1RTZ47yDRQvwKhypddFFK_6G3rEH4cpXb/view?usp=drivesdkWork got carried out and have had car back over week but when idling not in gear I can hear/feel ticking kind noise that disappears when I press clutch in.
I presumed it would be thrust bearing but garage confirmed this was also changed during new clutch being fitted.
They seem think it’s normal but I just don’t remember it being there before car went in.
Could it be anything else or do you think it just needs to bed in ( done about 300 miles since fitted )
Video is from a 130k km car. Also never seen a worse one.That flywheel is the worst I've seen.
Do you know a clutch replacement part numbers by any chance? My clutch started slipping recently (91k km) especially noticeable in 6th gear and will need replacing. My car is fully stock and I would prefer a stock replacement as I'm not looking to tune it in the future.Should not be ticking at all. Sounds like a flywheel issue to me. Here’s a video of one ticking: https://drive.google.com/file/d/1RTZ47yDRQvwKhypddFFK_6G3rEH4cpXb/view?usp=drivesdk
If it’s the flywheel and you need a new one, don’t get it from them, since you’ll pay A LOT over what it actually costs. Here’s the non-Hyundai part number (same part):
- LuK 415 1071 10
If it’s the clutch, make sure they bled it correctly. It’s not as simple as one might expect. Here’s the proper bleeding procedure: https://drive.google.com/file/d/16hDgrhMe6pd_CWy-1alNhFtK_V7nqVre/view?usp=drivesdk
Honestly, I don't. I never even considered getting another OEM clutch as it's more expensive than the RTS HD clutch and barely handles the stock power (I am stock as well).Do you know a clutch replacement part numbers by any chance? My clutch started slipping recently (91k km) especially noticeable in 6th gear and will need replacing. My car is fully stock and I would prefer a stock replacement as I'm not looking to tune it in the future.
Picture?Hi everyone,
I was just changing the oil in 60k km (37k miles) 2019 i30N and my mechanic found out in the gearbox oil pan metal chunk, a rather big one, like 10x3x1mm, does anyone know what it could be? The car has no problem with the gearbox at all, shifts fine, has no noises, nothing, and drives like new.
Thanks in advance!
Looks like gear synchro or gearbox guide fragment maybe?Picture?
