How you have glued 3d printed clip to the bumper?
Used this stuff:
Name me a date and I'll make sure to book my vacations correctlyHow about Motodrom Oschersleben next time? Should be located in the middle between our home towns?
Cooling ducts work great and always run fresh fluid. Spoke to Guys that race in Production Racing they like the OEM pads and if you want better brakes go to a complete Big Brake Package.Tips for brakes
Brakes -
OEM discs
Decent fluid (motul rbf6600)
Brake cooling (Audi RS3 Brake ducts clip to the wish bones)
Braided lines
Better pads like an endless or dixcel
For your next R spec tyres try Nankang AR1's very good for Track work and great value.This weekend it was finally track day time at the Bilster Berg again. Went there together with @Felix and a mate of mine. Main purpose was to have fun and to try out my Zestino semi-slicks as well as my oil cooler setup.
Weather was great with about 25C, maybe a bit warm, but I liked it
Car was great, no issues whatsoever, no components that somehow limited the fun I had.
Oil cooler worked perfectly, had 115C at the highest and after just a bit of cooldown down the back straight the temps were below 100C again.
Tires also worked perfectly. Ran them at about 2.3 - 2.4 bar hot which worked well. It seems the tires do their job between 2.0 - 2.5 bar quite well, had no chance yet to find the soft spot. But as I said, super happy with them. I don't have a direct comparison as these are the first semi-slicks I've driven so far on the track.
Sidewall also held up quite well although these are the stock dampers with close to zero camber!
Got a little clip for you (unfortunately only from my dashcam, but I guess it's better than nothing), just remember I am not chasing times, am an absolute beginner and we were 2 guys in the car with a bit of luggage.
Next steps are now the brakes, as this trackday shot the front brake pads and brake discs as you can see by the pics below. Wanted to go the slotted discs route, but there are no slotted discs with TÜV available yet, so I have to go the OEM-style route maybe with some other pads...
Tips for brakes
Brakes -
OEM discs
Braided lines
thats just street credThanks!
Apart from that crack in put in it![]()
Whiteline Anti-Roll and Anti-Lift are in
Quite a bit of work to get the Anti-Roll stuff in place, as you have to lift the steering assembly to place some spacers there.
Here are some pics where the corresponding parts got mounted:
Anti-Lift (spacers are on top):
Anti-Roll (the three spacers are mounted below the steering assembly):
I am bit bummed because the work for the Anti-Roll was a bit more than anticipated. I could have installed a front anti-roll bar in the same move, as the steps are very similar - well, maybe next time :/
In terms of driving behavior I noticed an immense change from the Anti-Lift. It does exactly what it says: There is literally zero lift of the front when accelerating hard - it is just glued to the road. Would not have imagined such a change after I've done new tires and the torque mount already.
The impact of the Anti-Roll is not that big. During daily driving you are not noticing it.
You can however notice it during fast bends (like 10-20° corners), especially when you take them hard and fast. The Anti-Roll can counter the movement of the chassis now and you don't have any body roll.
But as soon as the corner gets sharper, the Anti-Roll is at it's limit and the body roll is back. Only a proper Anti-Roll Bar will fix this I think. So I have to add a new part to my to-do list
What I also found interesting, due to the change of position for the steering assembly, the turn in behavior changes as well. It feels quite a bit more direct and responsive.
How's the ALK affecting the braking, dive and stability?
Since I put it in as Anti-Lift not Anti-Dive, the car now stays flat on the ground when accelerating hard.
Braking stability stayed the same or maybe got a super tiny bit worse.
it definitely was! plus, if the braking behavior is more important to you, you can install the anti-lift kit the other way around and it becomes an anti-dive kit!Thanks for that. I was thinking, there had to be a trade off somewhere.
Guessing there was more good to come than negative and was a worth it tradeoff.
