Brake pads
I haven’t seen the Brembo Xtra listed for the i20N, neither on the official website nor on any distributor catalogue. I suspect they just don’t exist (yet) for our car. Brembo is a bit vague with details, reading through the lines they seem similar to Yellowstuff. Maybe someone has tested them on other cars and can shed some light on them…
I'm currently using Brembo Xtra, been like 6 or 7 months maybe. Actually i saw someone wrote in here that he has been using and it is good, so i got it with the part code he gave to me. It is P 30 056X (not P 30 056).
In comparsion with the stock ones, i can say that it needs some temperature to work properly. The first and second brake may perform like %60 or %70 but after that it is way better than stock. Tested on track also, still better than stock BUT it gets hot and performs less, depending on how hard you are using on the track. I'm running with the forge braided brake lines and RBF 700. Also it is made of a harsh material and you may need to replace the discs with every set of the pads. But the discs are cheap so no problem. For the daily use, i can definitely recommend it.
In other news, my MX72+ have been finally shipped from Japan. For now cost of pads and shipping has been 229€, let's see what import fees I will have to pay, but for now not bad considering that in this moment you can find them on AT-RS.de for 558€!
What did the import fees end up being for the MX72+? Have you had a chance to test them yet?
Unfortunately, the earliest availability date for MX72+ at RHDJapan is the end of June :/ I then thought about ordering Project Mu HC+ brake pads; however, it seems that they don’t have a design place for a wear indicator:
So I’ll most likely go with your recommendation and try SDT RS-55 pads.
I've been using AI to try to work out which Brembo read pads are equivalent to OEM on the i20N
Narrowed it down to these two:
Brembo P 30 094 Brake Pad​
(e.g. https://www.amazon.co.uk/s?k=Brembo+P+30+094+Brake+Pad+Brembo+P+30+094+Brake+Pad&crid=P7OL1DZJ7OI2&sprefix=brembo+p+30+094+brake+pad+,aps,1187&ref=nb_sb_noss )
BREMBO Prime P 30 103 Brake Pad​
(e.g. https://www.autodoc.co.uk/brembo/14763462 )
Anyone know if either of these are the correct one?
https://www.bremboparts.com/europe/en/catalogue/hyundai-i20-iii-bc3-bi3-1-6-t-gdi-n/000145703-1
DS2500 installed, as OEM pads are cracked with 5mm left. Also wear sensor bridged, as it was already worn a little.
New products by Tarox on their website:
  • Range of front pads is now complete, up to (new?) Enduro+ compound
  • Added rear brake discs
  • Added new Sport Compact BBK that uses stock disc size and 6 pistons calipers (instead of bigger floating discs and 8 pistons of the regular BBK)
64€, still in the box! Waiting to finish the SDTs
I see that RHDJapan has more compounds available now
Hi jerome92, did you ever get to order the hc+ set? I will be traveling to japan this summer and thinking about getting a set to try if i can find stock over there. the prices are reasonable. I am quite worried about the noise though, if they will be acceptable for a daily driver, I haven't come across a reasonable review yet commenting on this. Some say they're unbearable at any temperature. Would be great to hear from first hand experience if anyone had tried it on their i20n.
No sorry. I opted for Endless because they are generally regarded as very streetable (but I have yet to put them on to confirm that)
Reactions: _LAH_
Thanks, maybe i can consult there to have a better real world opinion. Endless was another option for me.
Hi everyone,
I won the Turkish Touring Car Championship last year using the stock calipers, and I wanted to share some of my experiences regarding the braking issues we face with these cars.
First of all, the biggest problem on our cars is the amount of heat generated in the calipers and discs, and how difficult it is to keep them cool.
I have tested almost every brake pad and disc combination that has been discussed in this forum. I ended up completing the season with Tarox discs and Tarox pads, mainly because this pad compound has a relatively lower coefficient of friction and does not generate extremely high peak temperatures at the initial bite.
I have also tried almost every brake cooling solution mentioned here. Having tested them myself, I can honestly say that none of them made a significant difference.
For track day use, however, you have one advantage: you have the opportunity to cool the brakes between sessions. For that reason, I would recommend using the Tarox Corsa pad and disc combination and doing an occasional cool-down lap to keep temperatures under control. :)
Otherwise, you may eventually find yourself needing more professional and expensive solutions, just as I did.
Compact BBK still doesnt indicate whether it removes the need for a spacer vs the 8pot.
I was looking at minor brake upgrades (pads and braided lines) and wondering at what point the BBK makes a real difference as plenty of people still do track days on the OEM calipers.
my budget probably wont stretch to replacing the oem rims/calipers until late 2027 😔
I emailed them and they sent me the template for the 6pot. It just touches on the inner edge of the caliper and so I think it will need 5mm spacers to clear the OEM rim (unfortunately, as where I live wheel spacers are highly illegal). I emailed them to ask for confirmation, but no response yet.
The 8pot with 345x26mm disc clears without spacers, which is great, but besides being more expensive, this kit has very specific disc dimensions and pad shape and replacements can basically be sourced only from them and are quite expensive…
