Air Filter & Intake Discussion
5,023
I don't want to be a spoilsport but; the holes allow hot air to be sucked into the air box and mixed with any cooler air being brought in thru the grill area. What I'm saying is you've succeeding in creating a hot air intake. As heat soak rises within the engine compartment, more hot air will be ingested and systematically raise IAT's, reducing usable hp..🤔
Big-Ed
68
85
Scotland
Looks like Germany gets all the goodies with regards to I30n parts & accessories, Pipercross induction kit with the 'N' logo is a warranty approved part over there now!..
KawaiiiO
220
235
Mylo44
20
7
Kent
Hi All,
I’m running the ITG Maxogen kit on my 2020 N which I really like, however the kit utilises the standard intake pipe. I was considering changing the turbo inlet elbow & possibly looking for an take pipe which has a larger bore diameter. Does anyone know of an elbow / intake pipe that would work well with the ITG Maxogen?
Thanks in advance for any ideas / replies.
loafer-N77
1,512
1,935
Hi All,
Turbozentrum works perfectly!
Felix
264
380
There is one available for the VN thru the N-Performance Mall in SK, however someone did this with the original lid and I believe their a member here.
You can get them directly from Hyundai here in Germany:
Edu_250
12
9
Valencia
Qué os parece esto? ha mejorado notablemente el flujo de aire al turbo y la temperatura de admisión no es tan alta. Los picos de soplado medidos han subido hasta 1.4bar (ahora la ecu ha regulado y se mantiene en 1.2bar) y en añtas RPM se mantiene constante el soplado a 1.0-1.1bar
Estoy fabricando más para algunos propietarios que me han pedido una para su coche, 😁😁😁
Reactions: Ahtnukiav
nicosp
134
168
Cyprus
I think you accidentally posted in the wrong topic instead of the regional ones that are not using English language :)
Edu_250
12
9
Valencia
here in English😅
What do you think of this? it has noticeably improved the airflow to the turbo and the intake temperature is not that high. The measured blowing peaks have risen to 1.4bar (now the ECU has regulated and remains at 1.2bar) and in years RPM the blowout remains constant at 1.0-1.1bar
I'm building more for some owners who have asked me for one for their car😁😁😁
LewisYsC
Heyo,
I'm wanting to install an induction kit, before eventually getting a remap. I don't know too much about the inner workings, but my concern is if I got an induction kit installed would it make the car run leaner? Seen a lot of people installing induction kits with everything else stock, but I have no idea if it would actually decrease performance this way.
Cheers
