Nice! I keep going back and forth with oiled or dry. Feel like get slightly better airflow with the oiled filter, but the dry is just so damn convenient. Lol How does the intake sound compare to OEM?I got the oiled filter. I may purchase a dry one too though. You can get them separately. I also ordered my Afe intake directly from Afe. A couple times per year they offer a 20% off too. I have the Afe intake hooked up to a Velossa Tech intake snorkle. Works so good!!!!!! I am now going to install the Forge turbo tube to it but I cannot decide to just cut the Forge silicone tube or order a new 90 degree bend 3" one? I have a stainless steel coupler and a 4" to 3" reducer to make it fit. Come on Red, I need some answers. Lol...
Best regards,
-Mike
Cleaner as well. Take a look at the bottom of the Airbox the next time you're inspecting the filter.Nice! I keep going back and forth with oiled or dry. Feel like get slightly better airflow with the oiled filter, but the dry is just so damn convenient. Lol How does the intake sound compare to OEM?![]()
That's funny you say this, I was just thinking yesterday about running an intake tube from the fake vent on the driver side and debating on if that would help/hurt airflow. Lol would probably do that instead of the intake snorkle, but I feel like the more air the better right?The intake sounds mostly close to stock but the additional airflow makes the exhaust louder. They do have a plug on the side of the intake you can take off but I leave mine plugged since I have the intake snorkle. I may also fabricate something to open the plug up. Maybe some long tubing to go down where the bumper opening is. My only concern is that it may make the intake snorkle not work as good as it relies on pressure somewhat. I am going to go with just a 3" tube now. Red has talked me into it, plus it will be a much cleaner install. Thanks for the input, Red.
Br,
-Mike
You do not want to vent to the air, it's Illegal. Get caught, big fine! Plus you've modified the PCV system against what Hyundai allows. For recommendations to do or not to do try here;Speaking of cleaner. What are your thoughts on using a catch can, recirculating, or venting to atmosphere with our cars?
Thanks guys! Not a expert on the subject myself, so this is good info.You do not want to vent to the air, it's Illegal. Get caught, big fine! Plus you've modified the PCV system against what Hyundai allows. For recommendations to do or not to do try here;
Engine - Oil Catch Cans
My installed. Iām confused - what is the ID of the hose? One end looks fatter than the other. I know that 9mm ID fits the top on tbe casing (labeled as 9mm), but what is the ID of the other end that is labeled 14.5mm - it looks fatter? Referring to post #48.n-cars.net
Engine - Catch can
FACEPALM Is that like you...to yourself... after reading every word? :Dn-cars.net
