Yes as a matter of fact, I do;
C0A89APH00 Genuine Hyundai PD i30/i30N Fire Extinguisher Bracket
https://www.ebay.com/itm/Genuine-Hyundai-PD-i30-i30N-Fire-Extinguisher-Bracket/153299003076?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
You can contact; "Phil Gilbert Hyundai," thru eBay of directly on their website in Australia. They ship anywhere and are really great about communication and follow up.
Thanks for asking, happy to help. Keep in mind this is the bracket, not the entire fire extinguisher assembly.
Reactions: Appleton21
Hey ✋
I would like to ask you. I have Forge intake and I have problem with heat. The aluminium heats up and the engine starts to draw warm air so HP going down. Have you same problem ? Thx
Are you speaking of the Intake tube? If so, you'll need to cover it with a thermal or heat resistant sock or sleeve material. They can be purchased from several different companies;
https://www.heatshieldproducts.com/automotive/thermal-and-heat-shield-sleeving
https://designengineering.com/cool-cover-air-tube-cover-kit/
https://www.mishimoto.com/automotive/heat-protection.html?limit=all
https://www.thermotec.com/products/sleeving
Everyone has this problem to some extent. Products offered above^ will solve a majority of the issue.
The other issue is; heat soak. They have various products that will help specific areas of the engine which produce high temps. Once these are addressed, you'll have less of an issue. It will however, always be present to some extent, according to how high ambient temps are and how you are driving the car.
Keep in mind, it's not so much the heat on the intake tube but the higher IAT's. One of the best ways to address it, will be with a larger intercooler from; Forge or Wagner, etc. This will drastically cool the air being circulated thru the turbo.
You can also add; Phenolic Thermal Intake Manifold & throttle body spacer. The throttle body spacers, are available now but not the intake manifold spacer. It should be available soon, from Boomba Racing.
Check out; @TarmoT 364,5bhp i30ntracktoy. He's has been addressing these specific areas. He can verify what has worked for him, on his i30N.
Are you tuning or utilizing a tuner yet?
Reactions: TarmoT
No question is stupid in my thinking. We all lack knowledge from time to time and asking helps you to gain that knowledge. Thanks for asking.:) . I've actually been asked this before.
They come from Shark Racing and are magnetic door guards. They work quite well in protecting your doors, from the unaware driver who swing open their doors on other cars. :mad:
They have an elastic strap, which hooks on the inside door pocket. The magnets on the back side hold them securely to the doors. Pretty good protection, if you have to park between cars you really don't want too.:)
Boomba Racing Intake Manifold Spacer available and ordered. Throttle body spacer to follow shortly. If you decide to order, give me shout I can help you get a discount.:)
