Finally completed my setup...
The system is powered by the famous Pioneer D1004 amp and the speakers are from Ground Zero.. mid/sub in the front and full range in the rear..
Used the regular harness to install the amp, it is tight to get it to fit but it's doable... found a set of speaker adapters on AliExpress but they're not 100% compatible.. it requires some cutting on the adapter itself and on the original plug as the guides don't line up 100%.
Also added sound deadening material in the doors and trunk..
Overall very satisfied with this setup... it still requires for the speakers to settle a little more but so far with the current setting I can power it to the max without distortion..
