its a 4 ohm, same factory sperakersWhat exact model number were the helix speakers, specifically the impedance?
Helix
Hopefully I'll be able to get to it next weekend, with no interruptions from the dead rising and the ensuing zombie apocalypse...I will be following this with interest. I have just ordered the same, but am not likely to tackle the install for a while.
If it works ok with the original speakers installed then the head unit is ok. Put the helixes back in and see if the fault re-occurs.its a 4 ohm, same factory sperakers
Helix
I did several tests with the Helix and they do not work in the car, they only work outside, on a radio that I have in a room. My question was if it could have been due to the crossovers of the woofers The originals do not have a crossover and the new woofers if they did Maybe that caused an overload?If it works ok with the original speakers installed then the head unit is ok. Put the helixes back in and see if the fault re-occurs.
Is that on all four or only the rears?I did several tests with the Helix and they do not work in the car, they only work outside, on a radio that I have in a room. My question was if it could have been due to the crossovers of the woofers The originals do not have a crossover and the new woofers if they did Maybe that caused an overload?
How did you attach the speakers to the car wiring?change speakers in 4 doors, only no found 1 fornt and 1 rear
New Speakers Focal found ok
I suggest you speak to the shop you bought them from. So it works in the car when you bypass the crossover but if it's connected to the crossover there's no sound. If it works on other speakers with their crossover why not try the working crossover on the other speakers.directly to the speaker if it sounds
and if I connect the speaker with its crossover on an external radio it also sounds
just stop ringing in the car
If you swap the speakers around does the fault follow the speaker or radio channel?I have tested the Helix speakers on a radio outside the coceh and they work perfectly
The only place they don't work is in the car and only the front passenger side woofers (which make a clipping sound) and the rear side rear woofers not sounding
It gives me the feeling that the radio was somehow protected by the filters
But I don't know of anyone who has changed the tunics on an I30 Performance Facelift
And tell me about your experiences
I take the tweeters from the factory
And I'm afraid to change them in case I have a problem with the radio
Algunos tweerters son a 6 ohmNot exactly but I'd presume the usual 4 Ohm.
Follow the radio channel whenever I connect the Helix If I connect the factory speakers or Focal speakers without a filter, the fault clearsIf you swap the speakers around does the fault follow the speaker or radio channel?
That's really weird. Try a factory reset on the radio unit.Follow the radio channel whenever I connect the Helix If I connect the factory speakers or Focal speakers without a filter, the fault clears
