I tried the same ... Again an 8-digit password ... I will 'politely' ask a Hyundai engineer if he is able to share the passwordIt gets more complicated
Any news ?I tried the same ... Again an 8-digit password ... I will 'politely' ask a Hyundai engineer if he is able to share the password
Let me know if you find out?I was just amazed to find that my 2021 I30n fl is expecting a 6 digit password with the latest version. Is the password already known or is there a trick?
Mines asking for 6 digit code any idea what it is?I managed to enter enginner mode with this sequence:
Sel vol button to browse.
Set volume to 7
Goto home screen
Press ivi central knob
Set volume to 3
Set volume to 1
Enter password:
19500624 or 27021427 or 2603123
The first password worked for me.
Found an option to read DTC's but I don't know if it actually works since my car does not have any.
Also I found some wifi tests so maybe in the future we will get the wirelless AA and carplay.
Do You know the passcode for us here in Australia Clarky? Mines a 6 digit.Not here in Australia, you brick it you take it in for warranty
Did you figure out how to get rid of the warning on start up?Yeeesss. So you can change the N settings to make the car not that hard maybe we could give it a try to port the app "Torque" or anything like that to the unit
Also it`s maybe possible to remove the warning on the unit while starting the car.
I think I'll have lots of fun with this.
Yeah doesn't work for me eitherYou sure that you did the 5 taps on the left, 1 on the right of the system update button?
What's the password mines 6 digits?Dear all,
Is the latest password already found for the Engineer Mode of the I30N? All codes previously mentioned are unfortunately not working.
After the 5 taps left and 2 taps right in Version info, its requesting a password.
Thanks guys!
Amagawd what iz da codeWhat's the password mines 6 digits?
Ahaha n00b.You can 'reset' or better said clean up the signal using a DSP. For example the Mosconi DSPs come with a default cleanup map for our cars, which cleans up the frequency distortion from the HU.
Lol watIt would make sense for the manufacturer to rationalise production by using the same part. Look at partsouq.com and check part numbers.
Do you know what version you are running, is it Android or Linux?Do You know the passcode for us here in Australia Clarky? Mines a 6 digit.
It's the Latest 130 N version 2023 Australia. I'm pretty sure Linux but I could be wrongDo you know what version you are running, is it Android or Linux?
