My i20N
As usual, you have provided an excellent description. Also, you have unknowingly helped me out a bit.
I would never willingly try to change that part on my car but at least I now know what it is.
I was recently driving in a particularly rough part of East London. I was going incredibly slowly over some savage speed bumps and one particular speed bump hit something under the car making a nasty metallic scraping noise. On inspection the front of the car was completely untouched but the mount in your pictures was scuffed. So now I know what it is!
With my limited mechanical knowledge, I am presuming everything is fine because the engine has not fallen out 😳😆
It will be fine 👍. Even if it broke, or became detached, the car would still work but you might get a knocking sound when you accelerated.
Reactions: OldGit
I went for a ‘spirited’ test drive today and I have to say the Airtec torque mount is very effective! Acceleration is extremely immediate and wheel hop is non-existent. Transmitted vibration is slightly higher in frequency which I guess is because the connection is now stiffer.
Reactions: Wolle_75 and OldGit
A bit more progress on my speaker pods. The final alignment has been locked in using a laser sight and they have been set level so the logos line up nicely.
laser pointer fitted to speaker mounting:
cardboard stands in for the driver and the target for the laser sight:
stick used to check level:
First layer of filler applied - this stuff has strands of fibreglass in it and is nothing like normal car body filler!
I use one, and on several hard blasts the can picks up some down cooled aerosol.
I prefer a catch can as it should keeps the intercooler clean and also of course the hole inlet manifold, valves & burning chambers.
