To summarise the issues to watch out for:
A/ The latch hoop needs to be 8.5mm in diameter and not the 9mm it is now. Also the mounting plate needs to be set to the maximum adjustment as the latch mechanism (on the car) is not completely central.
B/ 4 bonnet stops that screw in and out for adjustment. These holes do not have to be drilled as they are moulded in, but the glass fibre is too thick for the rubber bumpers to screw in so I had to reach into the holes and sand the surrounding area from behind with a multi tool (Dremel).
C/ 2 further bonnet stabilisers. These holes had to be drilled but the rubber will just push into place and hold.
D/ 12 push in clips to hold the under bonnet pad. These holes had to be drilled but the clips will just push in and hold, same as C.
E/ The angled pivot support is already moulded into place but the hole in it is not big enough for the plastic retainer that the stock bonnet has (I lost mine whilst trying to fit it - it fell into the engine bay and I guess it’s hiding on the floor pan somewhere).
F/ The holding clip for the bonnet support rod. I had to cut a square hole for this. As with B the glass fibre is too thick and the hole is too small to be able to reach behind it so I modified the clip to work with the greater thickness of the fibre glass. I used my Dremel and a piercing bit to cut the hole.
This is not a 100% carbon fibre part. In fact I suspect it is mainly a glass fibre part with a top skin of carbon fibre. However, this is reflected in the cost and the top surface is real carbon fibre. What this means is that it’s not as light weight as a 100% carbon part would be but how much that matters is up to you - it’s still appreciably lighter than the stock bonnet.
The glass fibre varies in thickness from 2 to 5mm approximately - so it’s pretty thick in places.
This is an exact copy of the stock bonnet and the moulds have clearly been taken directly from one. Just like the stock one it is made from two parts glued together and so it is hollow. The benefit of this is that it means all the stock bonnet furniture can be used and, if you look closely, you can see where the holes need to be drilled.
How this bonnet compares to others on the market I don’t know and this is primarily because those other suppliers give very few details - certainly too few for me to be prepared to risk spending the extra money they are asking.
