My i20N
Hi,
regarding your engine tuning stage, I guess you do not run the 0w-20 oil spec anymore.
If you do use 0w-30, 5w-30 or even thicker, did you ever experienced any noticable differences in terms of engine behaviour/smoothness or even DTC/error code regarding camshaft Phaser timing speed due to the thicker oil?
Thank you
Sorry for the slow response but I’ve been distracted by non-car issues. I still use the recommended 0W-20 though it has been dealership serviced so who knows what they have put in it. What I can confirm is that I have not noticed any engine running issues and I have had no error codes. But to complicate matters the engine mounts are now so stiff that every vibration from the engine is clearly felt and you can feel as the engine warms up and becomes smoother. How much this has to do with the oil is impossible to separate from the engine mounting (The lower engine mount is the Airtec billet* one and the other two are Powerflex Black).
* I strongly recommend the Airtec (or the Whiteline which is very similar) as it’s appreciably better at maintaining grip than even the Powerflex Black. The negative, if you view it as such, is significantly increased transmitted vibration.
Interesting, I would not use a 0w20 with the tune from a technical perspective.
Also from the warranty side as you do get problems with warranty anyway with the tuning
I’m not sure what point your are making regarding the warranty but obviously I’m aware of warranty issues regarding tuned cars. As for your statement regarding the oil used - why would you not use the grade recommended - just stating you wouldn’t do it isn’t much use?
Reactions: det09
Higher pressure and temperatures at every critical point of the engine (piston, rings, valves and of course bearings).
You wear and shear the oil faster than with OEM engine. You want to have a higher hths and hot viscosity. Also better Noack for less inlet valve deposit. Also you have more oil dilution (more fuel). Just read the Infos in the Internet.
It looks like I would be better changing to Mobil 1 ESP 5W-30 or similar. Or 0w-30 has also been suggested to me.
Today I managed to corner my friend Dave and together we fitted the Forge Turbo Muffler delete that I bought some weeks ago (second hand but as new). As others have said, this is a very fiddly job! Mainly because it is directly under the point where the air intake enters the turbo - so it’s at the back of the engine bay and low down beneath other stuff. In fact you can’t see the whole part - you can just about make out the two ends and so access is the primary problem. So we took out the batter, disconnected one end of the strut brace (you may not have one) and removed the air intake (certainly the hose). Then you have to disconnect two cables and one has a bracket that needs to be unbolted and remove the turbo inlet connector (that the intake pipe connects to). All of this is just to get the access you need to do the job and even then it’s fiddly and awkward. We ended up using a specialist clip compressor we happened to have and both of our socket sets to get the combination of sockets and extensions needed - took about 2 hours.
So, was it worth it……? Umm, maybe but probably not. I can’t feel any difference in how the car drives but there may well be a bit more turbo whistle. My car wasn’t exactly quiet before this mod so it’s really just another drop in the ocean. The replacement Forge part is nicely made and fits well - but the stock part is also nicely made and the differences between the two, although clearing existing, are not as obvious as with some mods. I’m afraid I don’t have any pictures as there’s nothing much to see - just a glimpse of orange pipe buried deep in the engine bay. I think this is the first Forge part I’ve fitted to my car and the on-line instructions were very good with clear step-by-step pictures and explanation of each stage.
Stock turbo muffler pipe at the top compared to the lower Forge version
Well I’ve now driven my car a little more and there is definitely a bit more turbo whoosh and whistle - not vast, but clearly there. I don’t know how much there would be on a stock car which didn’t have a rebuilt hybrid turbo, but there we are.
I’ve done a bit of research on what a ’turbo muffler“ does and how it achieve its aims. Its purpose is to damp out the whistle of the turbo and it does this by creating an inverse noise and so cancelling out the whistle. The inverse noice is created in the same way as the sound one makes when blowing across the top of a bottle. There are slots cut into the inside of the metal sleeve and an air gap between inner and outer shells - this creates a Helmholtz resonator. Doing this doesn’t impede air flow so there is no reason why engine performance should be negatively impacted. The Forge part replaces the Helmholtz resonator with a solid aluminium component and so no noise cancelation takes place - simple as that.
Reactions: _LAH_
Today I made this short video of driving my car. The idea was to see if I could hear the turbo muffler delete - and whilst I can it’s pretty subtle. The picture and sound are both from my phone (iPhone 17e) and whilst the picture is pretty good the sound favours the upper frequencies over the bass. As a bonus see if you can guess what the top speed was - reached at 3:42 (on a private road).
  • Love
Reactions: HY1000
My latest car mod - well I’m not it’s a mod as such but n the heat of our summer (somewhat academic now) the power amp in my boot overheated a couple of times and the protection circuit shut it down! So I decided it would likely benefit from a bit of ventilation as it had none at all and, after using the car without its boot floor for a bit, I also thought the sub-woofer sounded better without a big chunk of felt and board covering it. So I’ve made this floor replacement from carpeted 6mm MDF and included three vent holes and a cutout for the sub. The sub already has its own protective metal grille so I didn’t think another was necessary.
Reactions: HY1000
If I only had the workshop, tools and skills I would love to do some of the mods you've done. Really not liking the idea of using my i20n as the first car to upgrade speaker system - what if I break, crack or scratch something 🥺 very inspiring to follow your progress!
Reactions: YNWaN
Thank you 👍. I used to have access to a very well equipped workshop but these days most of it is done in my back garden or in the road at my friend Dave’s house 🤗 (He lives in a culdesac)
Today I borrowed a thermal imager with the intention of seeing if the vents in the boot floor are doing anything. So I drove for about forty minutes with the stereo on and afterward looked at the boot floor with the thermal imager. I could clearly see the vents were passing heat and, in particular, I could see that the two vents that are directly above the amp were hotter than the third one. The temperature difference between the carpeted board and the vents was about 10 degrees C. So the vents are definitely working and helping to cool the amp! If I still get problems I will fit a couple of small fans close to the amp.
Reactions: The1Nonly
