The electric wear sensor is overkill in my opinion, even race pads have the metallic protusion that will start making a sound when the pad is almost dead. If finding a pad with the hole to fit the wear sensor is limiting your choice I would just short-circuit the wires. Especially if you pay attention to the brakes regularlyMy recent experience of the brake wear sensors.
On the i20N there are two brake wear sensors. One is on the drivers side front wheel and the other on the drivers side rear wheel. They are built into the inner pads and are of the sensor wire type.
However, I have Brembo calipers on the front of my car so the standard pads will not fit. The last couple of weeks I’ve found that every time I go into N mode a warning sounds and a message comes on the dash warning me to check my brake pads for wear before track driving! After some investigation I’ve found the front wear sensor has been cut off. I stripped off some insulation and tightly twisted the wires and wrapped in electrical tape - now there is no more warning. I’m soon replacing the discs and pads so this only has to be a temporary fix.
Much better shape than the ones i constantly see, keeps some sharp angles of the carI’ve been playing with my sticker cutter again. You may have seen that some i20N owners have blacked out the front bumper area around the fog lights, so I thought I would have a go. As far as I know, everyone who has done this have either cut the vinyl wrap on the car or used knifeless tape. I’ve tried using knifeless tape and it didn't work at all for me so I thought that, ideally, I could cut a sticker thats the exact correct shape and just stick it on with no further cutting needed. So I took a couple of pictures and started making a paper template. I then copied this template into some CAD software I have (much easier said than done). Three templates later I had it cracked and I couldn’t be more pleased with the accuracy of this sticker!
Before photo:
After photos - look how I’ve avoided the tow eye cover
Same as every other one i see now, your car your choice
