let me summarize what I told
@Dzhedaj about the module, maybe it helps the others as well:
Regarding the app control, you don't have to use the app after the initial setup. The box will automatically start up when you start your car.
As long as the box is connected and in idle mode (meaning you did not select any mode on the app) the Mando-Improved driving modes can be used using your steering wheel. This means you can continue to use your car like you did before, only the modes will all feel slightly different.
E.g. you can go to N mode using your steering wheel buttons and the suspension will also go to the Mando-defined N mode. You can then go back to normal mode using your steering wheel and the suspension will go to the Mando-defined Comfort Mode.
When you now leave idle mode by selecting one of the 6 modes from the Mando-App, these ones then will be applied all the time and will override any command given through the steering wheel.
E.g. you select Comfort Mode on the app and afterwards switch to N mode using your steering wheel, the suspension will still be in comfort mode.
The same behavior applies when you use one of the three custom modes in the Mando-App.
To go back to idle mode, just disconnect and reconnect the Mando module to the car using the App's settings.
Hope this clears it up a bit. Kinda complicated, but easy to use once you got it
Regarding installation:
The unit needs power as well as a signal.
Regarding power, it is advised to hardwire it, e.g. using a piggy-pack. If you know how to hardwire a dashcam, this one should be a breeze.
Regarding signal, it takes the signal from the steering wheel buttons. So you'd need to remove the lower steering wheel column cover and tap into the signal. Then just put it back on.
Hope this helps clear things up a bit. Imo a dedicated thread in the how-to segment would be a bit overkill, since the installation is so simple.
Regarding the difference in ride quality, check out the post in my thread, don't wanna double post:
Finally got the replacement for my Mando ECS10 Suspension Tuning box. If some of you followed the proper thread in the Suspension category (Link), you may have noticed the small challenges I had with the box. For those of you not familiar with the topic: The ECS10 is a suspension tuning box...
n-cars.net
