Good afternoon Kamik155,
I really like the red lateral insert on the side skits of your i30N: please,
can you put the link of where you bought it?
Thanks for your kind cooperation, ciao
Good evening Kamik155,
thank you for the kind reply: I found them OEM on ebay!
A warm greeting, ciao
After a long time - here I am again.
I didn't wrote at all because after great tuning by Markus in MTTuning I just didn't have ANY PROBLEMS with the car.
Car is still great and I have few days to my last Hyundai service - year 5 - so I ordered my checked stuff again.
The only new here are exhaust hangers from Powerflex (I ordered too many of them) and upper gearbox mount bush insert from Powerflex too. My service will be next week on tuesday.
Then "few other year services" - from wednesday - ceramic coat correction and new car stripes because one of the older stripes after winter cracked (about 1cm of crack and peeled off in this place).
At the end of next week I will post some pictures of the car with new toys and gadgets....
After "year 5" hyundai service everything with the car is fine. Exhaust hangers swapped to powerflex, oil, fluids and filters changed too. Intake filter and cabin filter from K&N washed and reoiled.
Next was my year ceramic coat service and carbon stripes change.
Here is the final result:
New spare hoses for Forge oil dual catch can - few months ago I burned some one of them by touching hot turbo side.
They made me two pieces with additional heat protection.
Still waiting for pipercross new intake and then I will install all of it together.
Pipercross intake kit installed.
It took me 3 hours in my friends garage. Some problems with silicon elbow - it was custom 150mm 76-102 so a lot of fiting, tightening and cuting few times then again with V3 add on kit and the same problem with pipe to BOV because my is custom too from GFB (fit/cut/fit). I changed one of the forge dual can hose too (that burned some above hot turbo side).
Pictures tomorrow because I just back home and it is too dark.....
Today was a great day and my birthday too..........
Here is a small mod just before dyno test:
Rubber gasket covers around the intake pipe and dyno test to check differences:
FINALLY !!! 400HP CLUB !!!
Second test was 1BHP less but torque was 529nm - I got info about wheel slip on the dyno roller (soft pumped winter tyres).
With older intake it was about 510nm so now should be the same or more.
It is a great present for me on my birthday.
.......I'm older but happy !
Forgot to add - I'm using now only RON100 fuel - Shell V-Power Racing 100.
Previous dyno with old intake and additional hole in the air box was on RON 98/100 mix.
All carbon parts are installed. It wasn't easy at all especially the console cover and small button covers.
I'm worried about these two parts because of the ambient temperature.
One thing I can recommend for sure - thinner 3M tape. In my case I didn't use it on console cover because my 0.6mm tape run out and I used stock one and I can see that this part sticks out more.
Here are pictures after:
View attachment 18768View attachment 18769View attachment 18770
The only thing it is not installed are wind deflectors. It is too cold and when I tried to try them on they crackled so I think they will lay somewhere and wait for the spring.
Hello, which glue have you used?
Car battery and fuse box covers from https://paintmodz.co.uk/
They are not direct fit covers like some expensive carbon fuse box covers from aliexpress.
This have more loose dimensions and have velcro tapes from the bottom not glue or 3M dual tapes.
I just wanted to cover some more the car battery from rain/water when the hood is opened.
Fuse box cover is just to better look next to battery.
Few days to my year service and this time - NEW BRAKES.
I have an appointment on tuesday and here are my new toys.
From TAROX:
From FERODO:
And accessories:
Engine oil will be the same like before - AMSOIL 0w30.
This time new brake fluid - was 660 now I will try 700.
The same oil filter and some liqui moly paste for brakes.
