Ok the pads are on. Thanks for all the advice, 3 out of 4 pads were cracked in the middle (example picture attached).
Sensor wire was not severed but looked melted. Shorted the leads with some quick solder job, shrink wrapped and install back on to the socket. No more annoying check pads warning.
Cleaned up all contact surfaces and slightly lubed with high temperature ceramic grease.
Went for a quick spin and first impression was too much pedal pressure needed for adequate brake force to be generated. Once i got some heat into them like 6-7 brakes from 70 to 20 and they started biting much better. Abs kicks in much easier with these pads.
One pleasant surprise, absolutely zero squealing. I was expecting them to squeal from what i read but absolutely none what so ever. I'm wondering if rhd japan painted turquoise over some standard pads and sell them as pmu =) that quite.
One snag though, through the end of my drive, i was doing the braking and accelerating back to back to make sure all is fine and there was a sharp metallic clank under braking from front left, like something metal under heavy load snapped. Felt it through the steering wheel. Was scary. Did another round of inspection and all seems fine. Retainer springs are in place, bolts are in place, nothing broken that i could see. I thought maybe I didn't seat one of the retainer plates properly and it snapped back in place. Guess i will never know. Did some more testing and call it a day.
