Brake pads
I put some brand new dba t3 4000 with some endless mx72+.
After a few laps on the nurburgring I think the rotors are warped. Crazy vibration when braking even on the street.
I paid 500 euros for these discs but they are shit.
The pad is great though
Seems like this is one of those areas where throwing money at the problem doesn't necessarily improve things. The rotor and the pads must get along well together in order to produce any improvement. Though I've also read many instances where a matched set of the same brand also didn't work. Go figure.
Having said that, my impression is that rotors are closer to the bottom of the list of things with the most impact in braking. I see them more as heatsinks. Increasing the diameter brings more heat capacity with added mass and cooling surface at the expense of higher unsprung and rotational mass.
Hi everyone,
I won the Turkish Touring Car Championship last year using the stock calipers, and I wanted to share some of my experiences regarding the braking issues we face with these cars.
First of all, the biggest problem on our cars is the amount of heat generated in the calipers and discs, and how difficult it is to keep them cool.
I have tested almost every brake pad and disc combination that has been discussed in this forum. I ended up completing the season with Tarox discs and Tarox pads, mainly because this pad compound has a relatively lower coefficient of friction and does not generate extremely high peak temperatures at the initial bite.
I have also tried almost every brake cooling solution mentioned here. Having tested them myself, I can honestly say that none of them made a significant difference.
For track day use, however, you have one advantage: you have the opportunity to cool the brakes between sessions. For that reason, I would recommend using the Tarox Corsa pad and disc combination and doing an occasional cool-down lap to keep temperatures under control. :)
Otherwise, you may eventually find yourself needing more professional and expensive solutions, just as I did.
Thanks for sharing your experience, you've probably pushed this car further than most of us here in this forum.
Your comment about cooling solutions (assuming mostly airflow related and well executed) proves that there is actually very little we can do in the way of improving cooling of the brakes which means the stock design is pretty efficient to begin with.
I believe pad selection inevitably comes down to availability at one point, because not every brand is as readily available anywhere in the world, limiting the already scarce options for comparison.
What pads have you tried with stock (or not) discs so far?
Did you brake in the new discs & pads?
yes I did a few stops from 120 to 30kph.
AFter that the brakes started squealing like crazy at parking speeds ( which is expected) after a few laps the squealing dissapeared and the vibration started.
I read online that it might be worth scrubing the rotors with some Scotch-Brite but not sure if that's a good idea
I agree.. At this point I might get some stock rotors next time or some plain zimmermans with a more aggressive pad (eg endless me22)
I guess your few stops were to early, discs/rotors mostly need 300-500km with a gentle brake in procedere, same on pads.
After these kilometres, you start bringing real heat in the materials step by step with the aggressive procedere, after that you need a long period of cooling the materials gently down.
Not really. I did more than 500km before I put some heat on them
So, I’ve (barely) resisted the urge to install a BBK and decided to give the MX72+ a go. In two weeks I’ll test them at the Misano race track.
I’ve tried to install the Speed Engineering universal brake cooling ducts for a bit of extra cooling, but they were either blowing air too low or ending up touching the wheels. I had to remove them, oh well I guess I’ll keep them for future cars…
Reactions: _LAH_
Looks great! What brand are the removed pads, not stock i suppose? There seems to be quiet a difference between the friction material surface area compared to the mx72+. I've only heard good things about the mx72+ i hope they serve you well.
I wanted to pick some up from Japan but turns out none of the retailers there can supply i20n brake pads locally, only export. So no pick-up for me. Some retailers even reject the existence of compatible pads. That makes me quite suspicious of the rhd offerings because they're not on pmu nor endless catalogues but here you are installing them and they look original to me on the pictures.
The only streetable option in rhd now is the pmu hc+. Mx72+ are made to order with a 90 days lead time apparently.
Reactions: Jerome92
The old ones were SDT RS55, pretty decent pads, but after the last track day they became quite noisy and there was no amount of re-rebedding in that made them quiet. Yes the surface area of the Endless is significantly bigger and indeed they are using around 5mm more of the disc both on inner and outer edge.
Pity that you can’t find them there, but yes they do exist :D
You can also check-out European catalogues such as at-rs.de and racing23-brakes.de: you will see plenty of Endless pads for the i20N. I actually contacted RHD last week to ask whether they could add other compounds, but they say they are limited to JDM ones only (for instance the “legendary” MA45B apparently is not sold in Japan).
As for the PMU HC+, I considered them, everybody says they are strong, but on the streets they get mixed reports, some say are very noisy and aggressive.
Anyway, I hope the MX will be good. I went (again) into the rabbit hole of studying ways of keeping the brake system cooled down and it seems the second most effective solution (after removing the dust shields) is to go for 2 pieces discs. Tarox does have a nice semi-floating disc with aluminum bell, machined steel billet rotor and directional cooling vanes…
i have pmu hc+ with a BBK and they aint noisy. however, the do feel a bit lazy on first bite cold, otherwise they have been great. very dusty too
Braking cooling is also a bit of a hard one to pick what works and what doesn't. i had a kit from a company and after 1 yr they have melted, and the piping was starting to rub through other suspension components.
Have put the factory dust covers back on as they do have some cooling design to them
Reactions: _LAH_
I guess i will find out about the pmu hc+ manners first hand. I will be using them on stock disks.
I also have mixed feelings about removing the dust/splash shields. Industry experts say it is a must, but i feel they're not causing that big of an obstruction to the airflow, particularly where it counts, to the center of the disk where the air is supposed to be sucked in. Speaking of which, would have been nice to have directional rotors. I believe our stock rotors are of the regular type where vane orientation is correct on one side and reverse on the other.
Reactions: Jerome92
To me removing them made a huge difference, before I was literally melting off the glue of the counterweights and actually damaged the paint of the rims too. Maybe they are not obstructing air flow and convection too much, but they are preventing heat escaping from radiation, which at these high temps is an important source of heat exchange
Reactions: _LAH_
Now i understand why you're seeking a bbk upgrade. This is quite extreme! Is this with cool down laps? Are you racing competitively or just track days? What circuits are you going on?
I imagine most of the damage would be occurring when standing still hot. Otherwise at least the rims should have adequate airflow to avoid damage from radiant heat.
I will order some heat indicator strips to try and see what temperatures the calipers are experiencing.
Yes with cool down laps. I do a “championship” based on lap-times, and only the average of the X best lap-times count so I can take cool down laps, but the time is short and I do improve a lot if I can do at least some consecutive laps.
Circuits are small-medium, Franciacorta, Varano, Misano, Vallelunga, Tazio Nuvolari, Cremona, etc for those who know
Yeah you are probably right on the standing still while hot, I guess it didn’t help that I was coming from an MX-5 that doesn’t have this kind of problem and so it took a while for me to adjust
Now in summer with heat strips on the “N” of the caliper I have measured 210C, which is pretty high, but calipers seem to take it quite well. It would anyway be nice to cool things down a bit :D
Reactions: _LAH_
