I had my first trackday with them on Saturday. Very satisfied with the performance, they never showed fade which is an impressive result. Nice little rocket the i20NI ended up getting the FriTech R60 and will see how they are.
The wear sensor breaks when it gives a warning and must always be replaced or bypassed to cancel it.I had my first trackday with them on Saturday. Very satisfied with the performance, they never showed fade which is an impressive result. Nice little rocket the i20N, here a video of my best lap.
Only thing, after 20 or so laps I got this message on the dash:
Which in English should correspond to this one from the manual:
The message does indeed appear now every time in Sport+, although braking is fine and ”visually” pads have much more than 4mm left.
I’ll have them checked, but possible that the wear indicator is not compatible with third party pads?
Does anybody know a way to disable this kind of dash message or at least how to mute the beep (which is quite annoying, as it was intended to be…)?
I confirm it was the sensor, the plastic head basically disintegrated with the heat generated by the more performing pads...The wear sensor breaks when it gives a warning and must always be replaced or bypassed to cancel it.
You can use the sensor also with aftermarket pads. It worked with mine till I melted it during a track dayGuys how do you deal with brake pads sensor on aftermarket pads? Do you cut the wire and short it or something else?
no electrical resistance needed?Just cut the wires and join them together.
It is just a loop. When the pads wear, the wire is severed and the circuit is broken, that is all.no electrical resistance needed?
does anyone did this like this and had no error codes or warning?
Edit: Do we have it only in the front or in the back too?
Yes, like that. Going by memory sensor is only on front right cornerno electrical resistance needed?
Didn't you have a wear sensor on the front right, at least on the i20N?We have used both for i20N & i30N EBC Yellowstuff front & back, I dont recall that we have to short circuit anything
