Drag to reposition cover
i30 N WoLf's Gengar
StefaN
67
44
Bochum - Germany
  • Changed completely the interieur lights to LED. The Lights of the back bank were pain in the ass because i got a pano and the original light were soldered. So i grabbed the soldering iron and changed it. I used 5050 SMD LED neutral white [Link] . The rest of the interieur lights were just a plug and play set. [Link]
Hey Wolf, I also changed the interieur lights in my pano hatch. Only the warm white fond lights still are on the ToDo list. Here I could use some advice. I unmounted the light elements and tried to dissemble them to reach the LED on the circuit board but I was a little bit scared to break something. Is there a trick to get the casing of the board?
Felix_i30N
27
19
Germany, Stuttgart
  • Flex Pipe: It's a completely different ball game. The sound is really incredible, even when the engine is cold he is much more "talking" and begins to bang in lower RPM's [Link]
Hi there,
so the flex pipe apparently changes the exhaust tone?
Cause I’ve heard a lot of different opinions regarding that one and I’m curious if there’s a noticeable change in terms of sound.
Cheers
answerk
9
hksar
I will try to post all conversations chronologically but i can't promise :)
  • One of my first things were to remove the badges and keep only the "N"
  • Found no older picture, here is the Hyundai/N Badge already foiled.
  • License Plate Lights: Just take a small screwdriver put them out and connect the new ones. Finished. Very simple but a bit expensive. The result is perfect (sry for the dirty license plate :p). [Link]
Dear Wolf,
I am the car owner from Hong Kong and I would like to change to the white led for the rear seat interior. is it easy to take out the LED board by heat three iron only? thank you.
