And I’m not comparing but simply saying, “AWD 30 years ago and today is a better choice than any current or FWD or RWD.”
What you posted above, is a direct comparison between AWD and FWD.
Yeah but if you drill down in the specs the AWD no longer has as big an advantage as it once had.
My Second car is a Subaru 3.0R wagon in 6MT and I will probably not sell it but the E-Diff now on the i30N coupled with the lighter weight, simplicity and lower cost of FWD kind of kills the AWD, I mean would you be prepared to pay another $5000 to $10000 for an AWD i30N ?
Watch the following, no longer the real need for AWD over here, maybe in the South Island in the snow but just have a second ol banger Subaru worth a few grand to go up the mountain, why use a new car ?
I disagree with what you’ve stated and will demonstrate further, as FWD has no advantages whatsoever over AWD. Nor given the same conditions perform as well.
Weight is nominal with the newer AWD systems for example; the Kona FED vs the Kona AWD;
Kona FWD; 3161 lbs curb weight
Kona AWD; 3327 lbs curb weight
166 lbs difference with the same performance ratings for the 1.6T and 2.0 NA. However, the AWD can go where no FWD can and navigate some of the worst road conditions a FWD cannot.
I can make other direct comparisons with both on and off the track performance for Audi and several other manufacturers in Road race and WRC configurations but above will suffice to provide a viable response.
Don’t worry, I did ignore the video. One video is not substantiated proof that even todays FWD can compare to an AWD then or now.
You can choose to ignore the obvious differences in traction and all out performance between the two but they will still be there no matter. What it all comes down to is, price point for Hyundai which are the low end of the retail automotive market.
Hyundai chose not to produce the N-Performance cars without AWD or RWD for; price point and additional complexity with the new wet clutch DCT. Not because FWD performance was on par with AWD, no matter how much you chose to fantasize about it.
Good thing as well, with the current mechanical and electronic issues developing with the DCT.
