Technical bulletin for misfire/high pressure fuel pump
Today i had the boost cut after going into 2nd and accelerated to 3000rpm for a second. 1st time its happened.
no totally stock and driving in normal mode and it just lost all power so got off the accelerator and then back on and it was normal and took off like it should. very weird
Reactions: paul-h
Presume you haven’t had the ECU change? Was the car relatively cold after starting? Mine did the same when the ECU issue first started. It usually manifested in the first 5 to 10 mins after starting. Always around 3000rpm.
Had the ecu changed but i had been driving for about 20 mins so it wasn't cold when it happened. Ecu was changed around 5 month ago. build number is 2227.
So would i be... so can sympathise with you... Your probably not hearing anything from Hyundai as they haven't a clue what is causing this issue... Which is precisely the reason I'm not bothering to contact my dealer at present.. as mine is running fine again at present... So in my case its just carry on driving it until it shows on a regular basis.
Bit of an update, had a call from my dealer today and Hyundai came back saying that the fuel rail pressure sensor (Maybe...) is at fault, so my cars booked in for in a couple of weeks to have this replaced. hopefully this fixes it and I feel like it might just do, fingers crossed
Good, good. It’s a fuelling issue so fingers crossed that does the trick. Really hope that fixes it for you.:)
Please make sure you report back and let us know if this fixed the problem. My car is an absolute pig to drive ATM. Virtually any full throttle application in first (or in second that causes the smallest amount of wheelspin) causes a cutout, the car backfires so loud it scares people, and pisses me off totally.
Yep of course I will, I'm in as much of a rush to get this fixed so others with the same problem can get it sorted as I am to get my own car sorted so we can all happily enjoy all of the 275 south korean ponies under the bonnet :cool:
Reactions: paul-h
standard pirelli pzeros corsa59?
245/40 R18 Bridgestone RE003s on 18x8.5" SSR GTX01s
19.1 kgs vs 23.1 kgs. Same diameter, but less un-sprung weight per corner, therefore it takes less force to turn the front wheels. It is possible to spin the wheels in 2nd gear under hard acceleration.
Whilst I also had the idea that changing the weight, offset, tyre size, tyre brand etc may have had some effect on the car, potentially causing the problem, the same problem is being reported on many cars running completely OEM wheels and tyres, AND my problem did not occur for the first 4 months of car ownership. I replaced the wheels and tyres at 1100 kms and the problem started just after 5000 kms.
Yet another, disappointing, update...
Had the high pressure fuel pump and the fuel rail pressure sensor changed on Friday, took the car out today and a tear fell from my eye as I floored it in third just to have the same pops and bangs out the back and the lumpy power delivery.
really annoyed, to the point where I had to stop myself turning into a couple of car dealerships on my drive about.
Emailed both my dealer and Hyundai requesting information on everything what has been done and why and let them know yet again of the issues and how annoyed I am to the point I'm starting to want rid of the car :mad::mad::mad:
It's just irritating as the misfire seems to clear after 45-60 minutes of driving which is weird, but then it behaves as normal and I can have some fun throwing the rear end out coming off of roundabouts with a bit of lift off oversteer! Which confuses me more as to what it possibly could be
Really sorry to hear your update. It makes you wonder what else in the fuel delivery system is still not right. So you’ve had both the fuel pump ECU and the fuel pump itself replaced, in addition to the pressure sensor?
Just the entire ECU has been replaced as well as the fuel pump, not sure if there is such a thing as a fuel pump ECU?? Cars aren't my strong point, I work on aircraft where there's a different computer for absolutely everything (Two of the computers are just for fuel!) so I end up getting confused sometimes
@coxy 2 carpets
I’m sorry to hear all that. What the hell is going on though? What’s your rights under the Consumer Goods Act (or whatever it’s called)? Is that an avenue you can go down?
Can I ask a really stupid question.....when Hyundai are changing these parts, are they actually fault finding, and then testing the car afterwards?
It sounds like a fuelling issue - so either the ECU isn’t programmed properly or the fuel lines or something in between. I’d almost be inclined to go back to the beginning again and look at the ECU.....
