Technical bulletin for misfire/high pressure fuel pump
I have looked into my rights and I think I can still reject the car as the problem came up within my first 6 months of ownership but I need to do some more reading into that.
And apparently they have done some fault finding and doing test drives after, when i picked it up this friday I came back to 15 miles left in the tank when I dropped it off with just under 100. And i've personally took out one of the mechanics before to show him what its doing.
Sound like a fuelling issue to me too, it can't really be anything else, Ill be speaking to them tomorrow and see what they say but I'm fed up of making the journey to have some half hearted work done for it not to be fixed.
Everything you’ve described sounds like a fuelling issue. When my ECU started playing up the car felt like it was starved of fuel.
I agree with the comments made by Crocoman with everything from fuel lines to the ECU being suspect.
I hope it doesn’t come to it but if Hyundai really can’t fix this fault you must have redress from your consumer rights. Here’s hoping they get to the bottom to it.
Is there a fuel filter, has that been changed?
Good point as dodgy batch of fuel and sediment in the fuel lines or filter might have been disturbed during the recent work. Have had such a problem many years ago but change of fuel filter and good fuel and all was well. Would hope a good technician would work through all fuel possibilities systematically.
Yet another, disappointing, update...
Had the high pressure fuel pump and the fuel rail pressure sensor changed on Friday, took the car out today and a tear fell from my eye as I floored it in third just to have the same pops and bangs out the back and the lumpy power delivery.
really annoyed, to the point where I had to stop myself turning into a couple of car dealerships on my drive about.
Emailed both my dealer and Hyundai requesting information on everything what has been done and why and let them know yet again of the issues and how annoyed I am to the point I'm starting to want rid of the car :mad::mad::mad:
It's just irritating as the misfire seems to clear after 45-60 minutes of driving which is weird, but then it behaves as normal and I can have some fun throwing the rear end out coming off of roundabouts with a bit of lift off oversteer! Which confuses me more as to what it possibly could be
I dont know if it's the same problem but when im going at 180km/h and after a while i want to floor it, the car goes up to 0.6 of turbo pressure and after some seconds goes up to 0.7 and no overboost! If I take my foot off the accelerator and back again, the car use the overboost and the pressure goes 1 bar. I don't know if this is some issue or not or if its just me doing something wrong...
Are you running a tuning box?
No, all stock. The car runs well I hit the top speed of 251 but this thing happens I don't know why...if the road goes up the car react without problems but on straight this happen some times
See my earlier posts about car running rough intermittently. It was loose ground connection between the cylinder head and the engine bay.
Only that every cylinder misfired but not the cause. They only found it after getting a tip from another Hyundai service centre.
But it was important appear something, otherwise they say it's everything fine or not lol. And you feel the missfire everytime in every occasion? 1st gear 2nd etc etc
so over the past week ive noticed my car stuttering, usually around speeds of 70-80mph. its happened many times and is not a nice feeling on the motorway. three times it has gone into what feels like a "limp mode". there is no warning lights and no warning of it being in a "limp mode", when i plant my foot there is hardly any power at all, all three times a simple restart of the engine when i get off the motorway has fixed the loss of power.
i called out roadside assistance and they found no faults with the OBD, took it for a road test and it unfortunately didnt happen on the road test, it is an intermittent fault. so they said there is nothing they can do and the dealer will struggle to find the fault unless they can replicate it themselves.
my car has 19K miles and is a 67 reg.
any thoughts?
not that i know of, i bought it with 1500 miles. its now done 19K but only experienced this issue in the past week.
i have just read through @Garth post about the fuel pump. it seems like a very similar issue and the video of accelerating with no power is exactly what i experience after it goes into what i thought was limp mode
