Technical bulletin for misfire/high pressure fuel pump
That's the correct part. I watched your videos and it appears that all power was lost. What happened after this? How long has the new pump been installed?
After that happend for the first time I turned off the car and everything goes back to normal after a few minutes.
If I just turn off and on again just the exhaust valves close, so the sound is normal, but the turbo still doesn’t work.
And maybe a usefull info, from time to time randomly the exhaust valves open - I loose pops and bangs and there is no difference between modes, also recorded it, will uploade it to the same link.
Try disconnecting the battery for 30 mins and touch the positive and negative cables together to discharge everything. Then reconnect and try again
My car was serviced 3 days ago, noticed today on first speedy run, turbo boost gauge only going ¾ the way and no overboost light coming on. They added a fuel treatment, could that be the cause? Not only that, there was only a quarter tank of fuel when they added it and my wife drove it til the fuel light came on before filling the tank with premium
