finished the install and I must say I am thrilled!
Much needed mid tones are here now and I can go to max volume without distortion!
here are some photos of the doors:
View attachment 2030View attachment 2031View attachment 2032
and some old vs. new...
View attachment 2033View attachment 2034View attachment 2035
i have found some molex mx150 male pins that fit perfectly into the fctory connector.
used some glue type heatshrink and tesa automotive tape to finish the instalation...
View attachment 2036View attachment 2037View attachment 2038
hope this helps someone :)
@Haba1205
did u install an amp when putting in these speakers? looking at doing mine in the near future
@Haba1205
you can check his build thread, he posted some details of his sound uprade over there :)
Reactions: ditrueman1
Ok guys stupid question but just trying to get my head around things as a newbie to car audio!
is there a difference between the front and rear door speakers? Will the same model suffice as an upgrade for both or do you recommend them being different?? If so, why!?
thanks in advance.
danny
thanks in advance.
danny
As far as I can remember front and rear are the same speakers, it's the amp that differs in power output for front and rear.
Reactions: loafer-N77
this is super thanks.
has anyone upgraded the front woofer and tweeter using an aftermarket crossover? How did you get the tweeter connection to the crossover in the door?
some ideas would be greatly appreciated
Danny
Danny
Under both front kick panels there are the main loom connections for the speaker wiring, get them from there.
Ok guys tearing my hair out here as well as tearing half the car apart!! Haha
attempting to install a woofer and tweeter in the front end with a crossover but have no idea which of these orange and green wires are the main output from the headunit and which lead to the tweeter and the woofer!!
any help is greatly appreciated.
Or is there an easier way to do it!?
Danny.
Apologies for all the recent posts. Newbie here
Will this help.
thanks it is some help but how do I actually identify which of the three pairs of orange green wires are coming from going to?! I can’t physically see where there are leading to from the main wiring loom.
Hope that makes some sense and really
Appreciate the time u are taking to try and help me. First time attempting anything like this and a bit out of my comfort zone installing the crossover.
thanks again. Danny
Look at this thread
I actually popped off the door card and measured through.
Look at this thread
brill thanks. I actually have the door cards off at the moment. What do you mean by measure through? And what should I be looking for?
Do you have a multi meter? In my sub woofer thread i actually specify which pair to use. If you have multimeter then set it to resistance and one end on the door speaker connector, choose either green or orange,then measure the corresponding colours on the floor harness until you find the correct one.
yes I do. Ok thanks will do that. Then is it just bc a matter of cutting and stripping the wires to connect to the crossover ?
