Does anyone know the code for the current update?
Guess it's "2900"
Thank you, I found out in the meantime.Guess it's "2900"
To activate the speed traps you must first make your phone a WiFi hotspot, then join the car radio to that hotspot. Once you see the WiFi icon in the top right corner you can then go into Navi options and turn on speed camera warnings, without the hotspot that option won't even appear.This worked for me.
Is it possible to activate the speed traps for the navigation?
Is there some way to code it in?
What do you mean by code?Does anyone know the code for the current update?
Thx mate. I didn’t give the feedback.To activate the speed traps you must first make your phone a WiFi hotspot, then join the car radio to that hotspot. Once you see the WiFi icon in the top right corner you can then go into Navi options and turn on speed camera warnings, without the hotspot that option won't even appear.
I found that after I installed my amp I could set the equaliser to mid on all frequencies. What software revision are you on?Does anyone know if you can flatten The head unit EQ in engineering mode? With an amp and new speakers installed I have to have the treble at -7! It’s So heavily EQ’d
I struggled with this quite a bit. The problem is a bit multi layered but I might have figured something out.I think it’s 112? Whatever the latest one is. Yeah i find the tweeters are very over powering unless you turn the treble right down
Chris
Have you thought about running a DSP? The issue with just running an AMP is that the equalizer built into the radio is not doing proper equalizing. It's just shifting the frequency curve and distorting it even more. The AMP is then obv amplifying that bad quality and your sound output will never sound super clean.I struggled with this quite a bit. The problem is a bit multi layered but I might have figured something out.
The only way I could get good clean output into my aftermarket amplifier was through Android auto(bt audio and aux in are unusable for sound quality). Furthermore I run active 4channel front stage only. The 2 front outputs are wired to the midbass channels low passed at 3khz max gain 80w. The 2 back outputs are wired to the tweeter channels high passed at 3.5k min gain. In order to reduce the signal output to the tweeter channels I moved the fader all the way forward.
In android auto mode I set the head unit eq to bass 0 midrange -10 treble -9(I run highly efficient aftermarket speakers and a good amount extra door insulation this will be subjective ) . I prefer a transparent sound but the N is quite noisy so bass presence needs to be kept in order to have an enjoyable experience at decent speeds.
Also no dealer has any idea how to set the output to external amp mode. It's probably just a redundancy left from the i30 platform because AFAIK the i30N has no factory sound upgrade. I wish we could get the answer to this, might be the missing puzzle piece to decent sound quality with no workarounds.
