Looking at these hyper gts for my MG. 19/8.5 ET45. 11kg
Now the search begins for track wheels. They need to be as light or lighter than the SSRs, and definitely 18"
I have longed for a set of Spoon SW388's for such a long time now (a Honda fanboy still after many years), and they have started producing them again, for the Civic Type R. https://www.spoonsports.eu/news/sw388/ The only currently available size is 18 x 8.5 ET45 5 x114.3, so light, and so track worthy. I have enquired, but I KNOW they are going to be REALLY expensive... "no official price has been released. However, the post did say expect it cost in the 'mid/high $3000 US range' for a set" AU $5000, or thereabouts....
The next option is a set of Rays CE28n's or CE28sl's or TE37's. Just a case of finding the right size.
After a full day's driving on the 245/40/18s, let me tell you I feel like the car is transformed. Same acceleration, no axle tramp that the P-Zeros seemed to suffer from occasionally, and the ride is just smother, in every suspension setting. The sidewalls are taller, but no noticeable flex in the corners, and I drove up a 45 degree curb this afternoon (with my son watching very carefully), and NO curb rash was even close to happening. I am a very happy camper.
I like your style sir!
I have a pair of 16" regamaster EVO's on my 99 civic EK. ~4kg per wheel I believe
Do know that Desmond will produce these wheels for Spoon sports. So maybe they will be a tiny tiny bit cheaper than the Spoon ones.
Indeed, They are very very expensive sadly. But it would be a very unique combo.Yes, very cool wheels, but ended up being just too expensive for irregular track use.
I bought a used set of 2017 Subaru Sti wheels, forged and BBS, so very strong and light. I had the centre bored out to fit the Hyundai, and the offset is +55, so the offset is identical to OEM wheels, meaning best handling and least wear on components. Used wheels (in almost perfect condition) and 1/2 used track tyres cost me less than 1/4 price of the 388's without tyres.
Loads of good info. Nice one. How do you find out the weights of wheels so easily?
Team dynamics any good or heavy?
I am looking at some Enkei EVO X wheels atm![]()
Be very aware that stock OEM EVO X wheels will NOT fit on the N, at least not without suspension and or guard work. I trial fitted a wheel (without a tyre) on the back of my car, it stuck out way too much.
These wheels are 18 x 8.5" ET 38. The wheels I run are 18 x 8.5" ET 44, and I reckon they are as flush as you want to go. MPSFunJet has 18 x 8.5" ET43, and he had the wheels measured up and machined to go as flush as possible. Only 1mm difference, but the BBS EVO X wheels are 5/6 mm wider on the outside.
Can the EVO X wheels be machined at the hub to increase the offset by 5 mm? If they could be machined down to ET 43/44, they would be sweet. I highly doubt it, I spoke to SSR about this with my wheels and was advised the wheels were manufactured for maximum strength and minimum weight, and they could NOT be machined without significantly reducing strength.
Not an easy car if you like a bit of concave style wheels
Thank you for the seal of approvalY
You have a tyre size I have NEVER seen (240/40R18), so I will assume you mean 245/40R18.
The answer is a definite yes! The wheel and tyre combo will sit about 4mm further in than mine, so they will still look quite flush, and will not foul the guards in any way.
An offset of 48 or 49 would have been my ideal if I could find the right wheels in Oz. We are not necessarily limited in choice of wheel, but sometimes the price of wheels out here is prohibitive, and the choice of fitments is limited.
I run 245/40R18s on ET44 wheels, and I have NEVER touched a guard with my tyres.
