Iv never had any issues tbh, i dont think there super strict. If there majorly poking out obviously they will take issue. But my wheels barely stick out, front go under as i run abit more camber and the rears stick by about a mm or 2How are the regulation with wheels & tyres poking out from the bodywork in your location?
Where I'm from, they must be contain within the bodywork, but it hasn't stop a lot of people from doing it.
Go with either 18x7.5 ET48 or 18x8 ET45 all round if you also have restriction.
The OEM tires (Pirelli P Zero) don't last long, so change them out if you have the budget for it.
You can transfer the TPMS from the OEM wheels, a lot cheaper then buying new ones.
It is forbiden if it poke out very much. But I dont care. My major concern is rubbing.
okay so both are ok, either 7,5 ET48 or 8 ET45.
Now, next questions.
Is 215/40 tire compatible with 8J?
what is better/worse for suspension. Wider rims and smaller ET or vice versa?
Thanks for your answer!Spec it would be around the same if running 7.5x18 ET45 with 225/40 tyres.. no rubbing for me.
Will They Fit - show they will poke 8mm from OEM which will look flush.
If you want to drop down to 17 size wheels, I would be more worried about brake clearance. Looking at Protrack One it does note it has the greatest possible brake clearance.
Good to know.On my i20N I’m running 18” 8” wide wheels with ET48 and there is no rubbing under any conditions.
I run 18x8 et 40 front and et45 rear, lowered on coilovers. No rubbing what so ever.Good to know.
I should have any issues then.
Thanks!
Amazing!! Thank you. Stock suspension right?I’ve got 18x8 ET48 and they are fitted with 225 width tyres. They fit just fine so you shouldn’t have any problem.
5 x 114.3Does anybody know the CB of the original rims? The hub is 67.1mm, but when I rotated the wheels I noticed that the rims don't align so well with the hub. Of course by properly tightening the nuts in sequence everything should go to its place, but I'm wondering if the original rims have a slightly larger CB than the hubs (I can't measure it with my caliper...)
YesAre the stock i20N wheel studs 12mm with 1.5mm thread pitch? Thanks.
