Not yet, only just ordered it so I'll let you have first stab at itHave you installed it? I am waiting on mine as well, should arrive next week, hopefully.
you could have done this in kick panels.
I did it that way.
https://n-cars.net/forums/threads/ena-by-haba1205.1773/#post-26340
That annoyed me in the beginning as well. I wonder how that will change after the new speakers are on..That's how my stock equalizer is set up waaay to sharp tones standard in this car
That's a bit weird.. The alpines should not be as loud as the stock speakers, as they are 60 watts RMS and require more power to be driven, comparing to somewhere around 20-40 that the stock ones are..
Sorry, maybe its a dumb question, but why did u connect the ones from the headunit?A soldering and heatshrink all in one solution
All connected up using the above
Thanks to all for making this DIY guide so simple. Over the weekend, I changed front and rear door speakers with Hertz components (front) and Alpine S class coaxial (rears), using a dremel to modify the speaker baskets, and soldering the wires to retain the factory wiring plugs.
It was worth the fiddling, as the results look neat and tidy, and the improvement to both the detail and performance of the speakers is simply HUGE. Its so good, i doubt i will need to consider an inline amp or under-seat sub.
In the next month I will have a go for the front tweeters, if i can remove the grilles and try to fit the Hertz items, without causing any damage.
Front doors I fitted hertz dsk 160.3, crazy price at AUD120, and rears are Alpine SPC-170 C-Series, full price at AUD119. Both were around 56mm depth. So as long as the mounting depth isnt beyond 56mm, you should be ok.Are you able to share the exact speakers you used. Going to have to change mine as the standard ones are just horrendous.
