i30 N How To: Headunit firmware & GPS navigation maps update
SomieI30N
2
Elgin
Hi, New here. :)
I am looking at doing the updates to my I30N.
Do i use the links posted as the update on the orginal post in the google drive or the links on post #50?
or are they the same just in a google drive?
thanks in advance :)
dualmaxi
Cracow
guys, did you know why after update to v112, in N mode app turbo pressure changed from bar to kPa, and cant change that?
dualmaxi
Cracow
You do that via the steering wheel buttons, nothing to do with the radio.
You’re right! But I had kind of bug, cuz both pressure types are set to Bar, on wheel display shows bar too, but headunit shows in kPa. Need to change to any other and back to bar, it works
Reactions: Jajodu
chris93
5
London
It looks like some of the facelift i30’s have the same Nav but with a more modern looking interface. Wonder if ours can be updated to look like that? Can the firmware from the i30 facelift car be sourced?
Jajodu
720
642
Bishops Stortford
The latest software for the radio is available for download in the forum. Changes the look and functionality of the infotainment system.
chris93
5
London
Thats great thanks, Does anyone have a change log or images of how the appearance changes? I will check my version when I am back with my car tomorrow!
Jajodu
720
642
Bishops Stortford
All the info is in this very forum, get a cup of tea and settle down for a good read.
V112 is the current one, there is a very recent update to that but I haven't managed to track it down yet.
Reactions: chris93
chris93
5
London
I have had a browse through and can see the changes Thanks.
If you look at a facelift i30 with the smaller Nav, example below - https://www.autotrader.co.uk/classi...ke=HYUNDAI&sort=year-desc&page=2&modal=photos
You can see that the interface, fonts etc look more modern but the head unit looks the same so wondering if the version newer then 112 enables this look!
Akiles
9
Bilbao
[QUOTE = "Jajodu, publicación: 95523, miembro: 1575"]
Sí, eso elevará el software a 112, también debes hacer los mapas porque son interdependientes.
[/CITAR]
I have the version v112 but it,s other older,I refer to a new update of fifteen days time ago because one person went to do the second revision and installed them.
Reactions: Jajodu
thorm
Home
Hello
I have the version without NAVI (only DAB radio and android/apple car play) and without SD card (only usb port)
Could I use this firmware to update mine?
Jajodu
720
642
Bishops Stortford
Hello
We had a question like this on this thread earlier, as far as I'm aware the USB port can't be used to upgrade the radio using the sd card software.
