Lol, yes, I see what he wrote, thank you for your copy pasteHe wrote:
In the break in process, you want to make sure that things really settle in with accordance to what the manufacturer claims the engine can do, so high RPM and heavy throttle input will provide you with a long lived healthy engine. The most important thing is to have the piston rings really settle in and that's done with wide open throttle (WOT). As the piston travels down the bore under full WOD it pushes the rings outwards at its hardest and creates a hard friction point against the bore which will make the seating and sealing for the duration of the engines life. Its the same with conrod bearings, main bearings etc.
I'm far more inclined to pay attention to the instructions of whomever is picking up any warranty claims than anyone who isn't...
Don't forget that with a new car you are also bedding in the brakes and clutch, wearing in the gears, etc. It's not just about the engine.
