There are lots of used sets available on market and brakes should fit 1:1 but you must also change dust covers too.What it cost to purchase and install, you can go with a aftermarket upgrade.
In facts my concern is that I have 18" rims and with an aftermarket upgrade maybe I will have problems of clearance for the caliper.There are lots of used sets available on market and brakes should fit 1:1 but you must also change dust covers too.
What about this brake kit for the I30N Performance, it sure looks tasty? Will changing the brakes void the warranty or better to wait until after warranty expires.
Does anyone know if the stretch bolts/need replacing, when fitting this kit or can anyone upload a copy of the hyundai workshop manual to figure out what would be needed.
https://www.forgemotorsport.co.uk/3...e_Hyundai_I30N_Veloster_N--product--1780.html
Very informative a detailed reply I have taken on board what you have said and will look into something else as suggested. So thank you again for the heads up.The question regarding voiding warranty or not is usually: did the modified part cause the damage you want to claim warranty for? If yes, warranty is no option. If not, warranty should cover the damage. However, if there are modified parts even remotely connected to any damage, HY might put the blame on these and it’s up to you to prove the opposite. Not impossible but definitely a pain in the a...
Regarding brakes: I’d stick to better pads, fluid, braided brake lines and maybe new rotors and if you really want to track that thing hard I’d go for something which is known around racing (which forge is not, sorry to say so).
