Brake pads
With the two persons method it is really simple: one pumping the pedal and the other cracking open the valve to get the oil out. The key is to not lift the foot from the pedal until the valve is closed and to keep topping up the reservoir, plenty of good vids on YT. Also important to use a good quality tube, I have the simplest kit from BGS and works great. I have now got their tube with non return valve so as to be able to do everything by myself. If you accidentally get some air into the caliper, just bleed some more
Absolutely not, I have done all of 2025 (20k+ km and 5-6 track days) and when I went to bleed the system there were barely any bubbles (but the oil was definitely a tiny bit darker than the fresh one, maybe because of some water starting to get mixed in?). This year I am trying to do it more often to chase the cause of the pedal going softish after consecutive push laps, but I’m getting convinced it is not the fluid or at least not an all out boiling issue (maybe air trapped in the ABS circuit or just an effect of having the whole caliper pretty damn hot and losing some stiffness)
Don't discount the pads swelling.
Yesterday I got to test my new setup at the track (video here).
I am very happy to share that the results surpassed my expectations, temperature measurement strips indicate that caliper temperature at most reached 166 Celsius (143C block fully changed color on both calipers, while the 166C block only had a partial color change on one caliper indicating that temperature barely reached the threshold or only for a very short time). Considering that last year I saw the 210C block changing color, this is a 30+C temperature reduction!
Most importantly the effect on the braking consistency was immense, for the first time I was able to brake at the same point lap after lap and having to back off only when ABS was starting to creep in due to tyre overheating. The difference was clear even simply standing next to the front wheels just after a session. I am quite relieved that I finally got this result, I don’t know which was the greater contributor among the discs and the new cooling, but I suspect that the discs played a big role!
As for the Project Mu, they were excellent: they were super easy to bed in (I got a nice pad material transfer on the discs with a minimal amount of repeated medium braking applications on the street), they have very good bite but have been absolutely quiet. When the brakes fully cooled down after the track day I had some vibrations, but nothing compared to the MX72+ and they have already almost completely disappeared (and again zero noise). Only minor complaint is that they wore down around 2mm after 75min of track time, which is a bit more than I hoped.
Perfection is still not there, the pedal was consistent but not rock hard (limit of the system? maybe worth trying Castrol SRF or Endless RF-650?). The guy who produced the discs recommended Endless ME22 for maximum durability, so at some point I may give them a try considering cost is roughly the same as PMU). But for the moment I enjoy this small victory and try not to kick myself for not having gone this route earlier 😅
Reactions: _LAH_
Congratulations! That is indeed a great result. I also think the discs made most of the difference but don't understand how =) Do these discs have directional vanes, are they labeled rh and lh?
Your previous discs were oem correct? If so can you confirm which side has the correct internal vane orientation for cooling?
Hc+ were completely silent for me also but developed a bearable whistle after my first track day with them. I also noticed the accumulated brake dust also effects this. The cleaner it is the more consistently it will squeal when warmed up. Not a problem for me at all.
Meanwhile i decided to go ahead with the dust shield removal after seeing 210+ on my last track session. Got some heat shielding for the wire harnesses (laminated glass fiber fabric sleeve with velcro) non reflective though, i will apply some aluminum tape at the areas closer to the discs for reflection.
I've also successfully traced and transferred the pad backing plate shape to my cad program. I just need to decide on the final shape of the shim and scale to the actual dimensions. Will report back if i get to produce a shim. (Will produce some extra if i can find materials)
I don't think your brake fluid gets nearly as hot as before but a ti shim should further help with insulation. Good idea sticking a temperature strip back at the piston side. I might purchase lower temp stickers to track piston temps this way.
Reactions: Jerome92
Correct
I had OEM, Zimmermann blanks and the last ones I used were Tarox F2000. None of these have directional vanes (they are purely radial). Tarox makes two-piece, machined, directionally-cooled discs, but they are significantly more expensive than what I paid mine (mine are surely casted, not machined, so will probably not last as long, but still...)
How much wear did you have?
Good idea about the tape!
Surely they help preserving the seals
Reactions: _LAH_
Good question, I didn't measure. I will try to measure if its possible to do it without removing anything. Mine should be much lower because i only take single sessions of 20 mins every month or so.
2mm is quite extreme, but again you've been driving hard more than an hour. (That is like a full super class race, maybe even including practice.) In this case they will last 2 days for you, maybe 3 but needs to be measured. The notes on the box says the pad is done when the friction material thickness matches the backing plate thickness if I recall correctly. And this was exactly the thickness where the slit in the middle would disappear, which is also the mid point of total friction material thickness. So the useable thickness should be around 4mm.
I was going to order some more to have handy when needed, maybe i should get one endless cc type also to try. But 150c working temp floor sounds rather high.
I had two more track days from the last message. The first one still with the Project Mu pads on a track that I know very well and that is very demanding on brakes: wear was still massive (from 8 to 4mm in 75min of track time) and - likely due to reduced pad thickness and the very little amount of cooldown laps - the calipers still reached 210deg. The feeling at the pedal though was still excellent, without fading and that annoying spongy pedal that needs a cooldown to go back to its previous feeling
For the second track day I installed a set of Tarox Corsa that I bought at a discount thanks to a local N-enthusiasts club. These pads impressed me for their quiet operation and they managed the track very well (although the weather meant that I couldn’t push 100% and the low temps surely helped). Main downside with respect to the HC+ is that the bite is clearly lower. The surface area of the pads is much larger though (similar to Endless) and general build quality seems superior. I haven’t measured them yet, but wear seemed good too
Reactions: _LAH_
I think 75 minutes of almost full send is already very very demanding on a car of this calibre. Most competitive racing series of this class only last 30 minutes, they rarely go above 45 mins if at all. Above which is mostly considered endurance and require an endurance oriented pad choice and possibly driver change anyhow.
So for recreational purposes, i believe your setup is pretty much bullet proof.
Having said that i am also surprised to see 210 degrees reached with your setup.
You've got everything right at this point, the only thing left is the caliper itself which has little to do with cooling or heat generation.
My next move would be to try a more racing/endurance oriented compound like endless me22 and see how it goes. I doubt it would generate less heat but i have no experience on those so who knows.
Reactions: Jerome92
You are probably right, but I skip the events’ free practice sessions otherwise the track time would be even more!
I agree, the high mu of the HC+ likely does not help with keeping temperatures down. For now Tarox Corsa seems like the best dual pad I’ve tried, together with the Pagid Street+. I would expect ME22 to be up there too
I am lead to believe that some of the guys in Turkeys circuit championship have solved their brake temp issues by replacing the aluminium brake piston with a steel unit? Has anyone got any information to confirm this? Also it would be useful to know the piston dimensions if anyone cares to make the measurement when doing a pad replacement.
I doubt the stock pistons are aluminum. I believe they are chrome plated steel but can not provide concrete evidence to support this. Next time i change my pads, i will test with a magnet.
Dimensions are sometimes listed by online parts dealers. You can't really measure the exact dimensions without removing the piston but we know its 54mm in outer diameter. Thats as thick as the width of the pad backing plate, so can't be larger.
There is only one person here that I know of who actively competes in the turkish circuit championship. He has a thread about his heat management question (the only place in the forum he ever posts) but rarely, if ever, answers ours =) at least that was my experience. I remember that post of his where he mentioned solving the brake issues with switching calipers (with steel pistons) prompting some questions on my side but never got an answer. It mostly works one way with them I guess.
What he meant by switching calipers is going to aftermarket calipers i believe. A steel piston alone would not contribute much to heat management of the complete brake system.
In my opinion it's about how effectively you disperse heat from the source. Biggest contributor would be proper directionally vented discs. If insufficient, fresh air delivery to the center of the disc should improve things further. Second would be to thermally isolate the brake piston from the pad. Assuming you have the right pad compound, this should pretty much bulletproof your brakes in terms of heat management. The rest (steel lines, stiffer calipers etc) is about feel.
I agree. Additionally, aluminum is 5x better heat conductor metal than steel, the cooling would be better, not worse if it was aluminum.
You're right about aluminum being a better thermal conductor. However caliper piston is a part where less thermal conductivity is better. It would be conducting that heat to the brake fluid behind it, where it is most harmful and cannot be dissipated.
I think maybe there was some mistranslation involved when I originally read a comment refering to this somewhere on Insta (I think). I asked AI and it claimed that the calipers were being modified with aftermarket parts from Mando but did not give a referal link to this so it is probably halucinating.
