Correct Nullo, VN's and i30N's are equipped with MAP sensors. There won't be any problems for either; dry or oiled filter.
Can you please post the website here you bought it from?
It depends - sometimes just a piece of cheap metal, can be 10 times more expensive.HRE snorkel is 299€.... way to much for a little bit of plastic
In my oppinion it is still better to spend 300€ for something what improves performance of your car than spend 340€ for someting what looks good (Forge hot air intake) but will steal some power from your car.
I have just purchased and fitted the IFX intake kit. It is Australian made and he sells them on eBay. I was looking at the Forge however I didn’t like the lack of hot air shielding, and the only benefit seemed to be the noise it would make. This was the only intake kit I could find with a box around the filter. Price was a bit steep at $670 but in my opinion it was the only one that should actually lower intake temps so it was worth a try. The bottom of the box stops at the edge of the chassis rail which allows cooler air to be drawn from the inner guard area. Quality is excellent as was the packaging and instructions etc. Plus the sounds it makes are awesome!! View attachment 8141
Thanks for the write up! Any chance you can take a video?
I might have to blow my tax return on the one... however murphy's law states as soon as I do a sealed intake with front snorkel will become available
That intake has one weak point - silicone connector between hard pipe and heat shield. That heat shield has a welded flange where hard pipe will be attached from engine side and air filter from heat sield side. Problem is that our engine is moving backwards a lot and intake system must have also 1-1.5 cm room to "play".
But you can fix it by using hump hose:
Otherwise that solution looks solid and if you will also modify your lower left bumper grille and bring flexible pipe close to the filter, it will start to work even better.
Not sure in your laws in Germany but here in Australia a pod filter is a defect if it’s not in a box. While this isn’t technically a box, once the bonnet closes and seals it sort of is. Well that’s the argument i will be having if there is ever an issue. Mind you I haven’t had any issues with modified cars since my teens and never driven a standard car (or not for long).I'm so fu***** jealous right now. Damn laws in Germany impossible to drive with that here.
Looks so sexy and sure sounds even better.
