Technical bulletin for misfire/high pressure fuel pump
This was exactly the points I brought up several months ago, all be it for a not so serious issue. It seems they haven’t listened, unsurprisingly.
Such a shame some cars have these faults and the dealers are unable or unwilling / not capable to sort them.
I still think it is a small part of the cars that have been sold that have these issues, it's just that we're all on this forum that sort of magnifies the problem.
My car is an april 18 car to. Done 15000 km and so far no problems, only a little cracking noise in the dashbord. No problems with hunting revs, misfires, gearchange, ... so it must be doable to make your cars run as they should. Keep the faith!
Ah, I didn't get that vantage point during purchase / pickup - I guess I can ask (I think they're getting use to me hanging out there). Just received an invite for their new i20 release party. Might have to use that opportunity.
Reactions: Brendan
It’s a shame all manufacturers sell cars with known faults and it works out on a cost ratio balance. Sometimes it’s just luck, some people experience these problems and others never do :confused:
This whole ECU ...Fuel pump saga is a farce.
Had mine done a while back now....was running fine for about 6wks...then out of the blue...it didn`t want to start one morning...then started and ran fine for a short drive.
Started ok again after being parked for a few hrs...but started miss-firing for a short time after.. for a few mls... then cleared for the rest of the journey.
This was about 8wks ago and has behaved fine since then.
Before the replacement I had no issues whatsoever.
This and going by what others have posted on here....implies to me... that Hyundai really havn`t a clue as to what is causing this problem... after the best part of a year... and well over a thousand sold.
I share your frustration. Hope the misfire is a one off. Particularly as you had no fault before the ECU change. There is something about engine temperature in all this. Before my car failed completely it was very bad for 10 - 15 mins after a cold start and then usually it settled and drove perfectly. Is it possible that the fuel pump itself and not just the ECU is a factor. Some cars have had the fuel pump replaced as well I gather.
As true as that may be, I think that they have already addressed these (known) problems, as all current N's (starting at some point before summer '18) come with the "new" ECUs, fuel pumps, or whatever the other problems may be. Take also into consideration that many of those reported problems are supposed to be controlled/adjusted on the pre-delivery inspection (rear camera, radio software, headlights adjustment and the list goes on..) and so far I've been reading not so positive comments about the dealerships in UK.
The dealer told me (for what it's worth) that my car was one of the first to leave the productionline with all the modifications needed to solve all the known problems at that point. I than tought: yeah right, you're just trying to keep me satisfied.
But untill now I can only say he has been right... Are there any cars with known problems as mentioned above that have come off the line after april 20th 2018 (that's when mine got produced, not delivered)?
I'm not frustrated about it Scooby... I'm annoyed.... Going from a car that never gave me a single issue... Having the recall for ECU to be changed to one that would eliminate the possibility of me developing one... Has in some way introduced a gremlin.
OK... only happened the one time to date ... So possibly a one off event... or something that might happen again at a more inconvenient time with dire results.
Since my car went in last week for a health check, it's been transformed, gear changes are now smooth and the car feels significantly quicker.
I went back in today to find out what they'd done and the technician said that he'd only plugged in the car to their diagnostics to see if there was a software update (which there wasn't). I'm pretty convinced that something was reset when it was plugged into the diagnostic computer.
Okay so after having the ECU replaced and this NOT fixing the problem, it was in the garage today for a days worth of data logging and testing, the results of which have been sent off to Hyundai so within the next couple of weeks my dealer should receive instruction from Hyundai as what to do.
I'm obviously let down as I can't drive the car properly, but is there any possibility of damage being caused from this?
