Yep thats mine cold, usually run up to around 39/40 and 38/39 from normal driving but had them up to 42 hot on the fronts before from a little bit of right footage ;)
Don't forget that there is approx 2psi difference per 10 degrees celcius change just from the ambient temperature. So 38psi at 30C from the recent good summer in the UK will only be about 34 in our 10C autumn days and 32psi at 0C.
Hi chaps,
How do the stock Pirelli P-Zeros do in cold weather or the wet?
It's close to winter tyres time, but not sure when to change.
Read some reviews of the Pirellis being shocking in the cold or the wet, but they're not the HN specific ones
Cheers
Ricks
I
Hi chaps,
Cheers
Ricks
I have my gti on P Zeros all the time never had a problem even last winter in the big freeze I managed to drive an hour home on them
The manufacturers advise 7c is the change over temp however i find if your not silly and drive sensible you can prob go to 2-3c.
Also will depend where live up the North i do not fancy runnig P zero's @ 0c in the snow, but down south they may get away with it
0c is 0c no matter where you live, number 1 factor is driving to the conditions of the road even on “winter” tyres I wouldn’t go hammering around in the snow
Sorry i should have elaborated i was referring to 0c with no snow on the road is doable provided your switched on. 0c with snow and ice like we get in north would be silly even if your a switched on was what i was getting at :)
No worries, just found a little snippet that insurance companies are getting out of claims payouts because people are putting on different size winter tyres on from the summer. So I know Hyundai recommend changing to 18” rims for winter tyres. So would that mean you would have to inform your insurer ( and incur a charge ) or if you have an accident you won’t get paid out?
yeah changing your wheels even for the better (safer) would be classed as mod and room for them to wriggle out. They could argue the the increased confidence attributed to a bump
Absolute gits, even when it’s recommended by the manufacturer for safer driving :mad:
I'm Scotland based, so we're about 10-15 oC at the moment. Which is close to winter tyres temps, but not really quite yet!
Pretty tempted to just put All Season Bridgestone A005 for the generally Scottish weather - even though it's been an amazing summer, it's usually wet and cold up here!
Reactions: Safcwarrior
Just fitted my "winter" wheels and tyres.
Really just 18" wheels with wet weather tyres tbh.
I've fitted Uniroyal Rainsport 3's which I've used before, great wet tyre and pretty quiet, but poor wear.
I’m starting to look at a new set of fronts which will time quite nicely with the climate change up here in Scotland. I quite like the look of the Goodyear Eagle F1’s but I know you can’t go far wrong with Michelin Pilot Sport 4’s.
Wear on the fronts is slightly more on the edge (as expected) but generally pretty even across the Tyre. Sitting between 3-3.5mm.The rears still have 6mm after 7k miles. Just standard tyre pressures for me at 38 and 35psi iirc.
