Hyundai took reading's of my tread depth 2 months ago when in for an oil change and asked if I wanted them changed after only 2800 miles.They still had plenty on them,went in again 2 week ago for ecu change and thought they would mention it again.There fine we measure the depth from the very edge of the tyre other places don't do that so there ok she said you would be wasting money if you do,how very honest!
Reactions: WookieeM
Would like to know if the tracking is out from factory, and if it is if they would reimburse you for premature tyre wear?
I keep trying to get under the car and have a good look at the alignment but I am getting close to having it professionally looked at just for some piece of mind, I've had a quick search but couldn't find it but I'm sure someone else had tracking issues from the factory?
I have gone the whole new wheel and tyre route.....
I didn't dislike the Pirelli p-zeros, I just didn't particularly like the wheel design, the wheel size, and the super hard ride of the 35 profile tyres, plus the terribly short tyre life being reported here.
Add to that Hyundai wanted $2100 for a new rim (for a full size spare), $500 for a tyre, $300 for a new TPMS, and $50 for a centre cap!!! (Aust. Prices) $2950....
For $50 less, I got a set of SSR GTX01 wheels in 18 x 8.5", 4 matching SSR caps, and 4 Bridgestone RE003s in 245/40R18. $2900...
Sold the OEM wheels and tyres sans TPMS units for $2800....
Very happy with tyres, after 4000kms, they look less worn tham the p-zeros after 1100kms of run in driving. I have been getting 14 - 16k kms from RE003s, so happy with that.
I ended up buying a steel rim custom made to my SSR specs, 18x8.5 ET44. Fits over the big brakes, and a used RE002 for $50, cost me $250 for a full sized spare for those long trips.
Thanks for the info, I'm going to seriously consider these tyres when I change over, but on the original rims.
Hello everyone,
I am an i30 owner with the stock p-zeros already worn out to around 75%-80%. My intention is to replace the p-zeros for some others with less adherence, more durable and higher profile, so they are also safer for the rims. Now, has anyone tried to install something thicker than 235/35 ? Is it bearable for the suspension and wheel clearance to have something like 235/55 (4cms more of wheel height from the ground) ?
Any help, comment or feedback will be welcome.
Overhere (Belgium) that wouldn't be legal on 19 inch.
Don't think it would be driveable: difference in speedometer, wheelclearance, ...
Would look for something like 18 inch.
I’d love to go Michelin Pilot sport 4s but I know Michelin’s tent to have a rather squared side wall and now im running H&r + 15mm spacers, I don’t think they will fit under the arch without rubbing as the p zeros have quite a lot of stretch
Reactions: Rich and BadShadd
Hello everyone,
Hi deFlanker,
Not sure what road rules apply in Switzerland, but here in Queensland Australia, the following rule applies:
For a passenger car, passenger car, derivative, or ‘soft roader’, the overall diameter of any tyre fitted must not be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that model.
Increasing your tyres to 55 profile would increase the diameter from 648mm to 742 mm, a whopping 94mm increase. Totally illegal here. Even just increasing the profile from 35 to 40, means an increase in tyre diameter of 23mm to 671mm. Still illegal in Australia, but may well be legal in Switzerland, but I doubt it.
55 profiles would make your car accelerate like a slug, the increased diameter, increased weight, and therefore increased rotational mass would require much more power to turn the front wheels. And your speedo would be 14.5% under, meaning, at 100km per hour indicated, you would actually be doing 114.5 km/h. Again, not legal for your speedo to be that far out.
Handling would be affected by the softer, bigger sidewalls also. And I would think you would have horrible clearance issues with such big tyres (height and turning wise). And I suspect you would void your warranty.
I went the entire wheels and tyre change. 18" rims, lighter and slightly wider 8.5". I fitted 245/40 R18 tyres, Bridgestone RE003s. They cost 1/2 the price of the P-Zeros, and after 3,000 kms, they appear to have less wear than my P-Zero's had after 1100 kms of running in kms.
The new lightweight rims IMO look better than the OEM rims, they weigh 4.5kgs less per corner, and ALL FOUR high quality rims cost $200 LESS than ONE OEM rim!
Going to 245/40 R18 tyres, I increased my sidewall height by 22%, about 17mm, and haven't had a single scrape since. And I increased my overall tyre diameter by just 5mm, or 0.8%, so the wheel/tyre combination is legal (where I live), and the speedo is off by less than 1%. At 100 km per hour, my car is actually travelling at 100.8 km/h, no biggie.
And the lighter rotational mass (my wheel and tyre combo weigh about 4 kg less on each corner) means the car accelerates faster. At least I think it does....
The only way you could use higher profile tyres than 40 profile would be even smaller rims, and I don't think 17" rims will clear the brakes.
Check out your local laws BEFORE making such drastic changes. I agree that the P-Zeros have very poor tread life, but putting mediocre passenger tyres on a performance car is NOT a smart thing to do. EVER!
I am running 245/40 R18s Bridgestone RE003s, which also have a very "square" sidewall, I am running 8.5" rims with 44 offset, so I have the equivalent of 17mm spacers (11mm smaller offset + 6mm wider on each side of the rim), and I have NO issue with rubbing. But I do NOT have the h and r springs.
I agree with you, I think it may be too close for comfort on the lowered springs....
Have heard Pirellis can get a bit loud once 50-60% worn... Will see how mine get on, but am likely to go for Uniroyal Rainsport 3 when the time comes. Ran them on my C63 and they were superb - quiet, good ride quality, awesome in the wet, and negligible difference in the dry to the Conti CS3/5 that were on that car when I bought it.
I'm leaning towards the Michelin ps4s. Seems like the best compromise. I wouldn't be comfortable knowing the wife is out driving on cold track tires in damp weather :confused:
Here's a great test on a focus st
Reactions: aca_nl
nice minimal wear! What pressures are you running
38 front 35 rears.
That's the front right, rears are better, as you would expect.
It's pretty even wear across the tread, with just a touch more on the outside, which is to be expected through cornering, I guess.
Reactions: Stash-N
As the middle tread is less worn on every tyre that would imply underinflation, which is a surprise given the stock pressures. I also can't believe that a new P-Zero has 10 mm of tread.
Reactions: padigree
