My i20N
I have just checked what my puddle lights look like now that I have removed the N logos from them and this is the result - a bit less cool but a lot more practical in terms of lighting the area outside the door.
and this is what they were like before - well, when they were new and not damaged by the heat of the COB LED.
Looking great!
I just received mine and looking to install it. How did you expand the rivets after inserting them into the designated holes? Was a special tool required?
Just wondering if any special tool is needed before I start this job :)
Rivets? Oh, you mean the riv-nuts - yes, you need a special tool. You can buy a special ‘gun’ for fitting them but you can also buy simple bolt and spacer gadgets that do the same thing. I got mine from eBay and it was a few pounds.
As I have a sticker cutter, and I’m not able to leave things alone, I drew this design for my otherwise plain carbon gear knob. This is pretty much the highest level of detail I can achieve with the cutter I have - trying to cut numbers this small is too much of a challenge for it. I might be able to cut the numbers a bit larger and separately - I’ll give it a try 👍
I also did these wheel spoke decals a few days ago - but I decided I didn’t like them so they are not fitted any more. That’s the nice thing about stickers, you can always peel them off. They might look better if done in red but that’s too bright for me (for now anyway).
Reactions: tymkuc
I‘ve also had these winglet decals on for the last few months. Despite taking quite some time to draw them I’ve now tired of them a bit and removed them too.
Reactions: tymkuc
In fact I’ve now removed all stickers from my car, no club stickers etc. and all that is left are my N badges on the front and rear and the side skirt decals. The side skirt badges are actually the 3D printed ones from i20n_brass, but I have wrapped them. The front and back are black badges from AliExpress (get the matte ones because the lacquer fails on the gloss ones) and I drew and cut custom colour overlays to match the car colour.
Reactions: tymkuc
So, I did indeed cut some separate numbers for my gear knob decal and they seem to have come out pretty well - apart from sticking the 5 in the wrong place (I’ll move it tomorrow). I even drew my own font out so that the cuter would have an easier time 😆🤗. I’ve got some CF finishing resin and I might just coat the knob so that everything is sealed into place.
Is the cutter an expensive bit of kit? Recently wasting vinyl using a cutter when i mess up or not being symmetrical makes me curious about it. Plenty or spots on the car id like to design more for but the cutting bit is stopping me
Interesting, not as expensive as i thought, thanks
Reactions: YNWaN
Six months ago I was absently scanning eBay and I saw someone selling an unused rear strut brace for an i20N. So, as I already had the front brace I thought fate had spoken and bought it. Now those in the know will be aware these official braces are via Hyundai Germany and so the instructions are in German (only) - but Google came to my rescue. Anyway, it was a nice day today so my mate Dave and I finally fitted it. Quite a pain in the ass really as the rear seats have to come out - certainly the seat backs. Four holes have to be drilled out and rivnuts fitted. Then the plastic trim has to be cut. And of course it all has to be put back together neatly and properly. But…. all done now 😆😎👍.
Ignore all the audio gear, that was professionally installed over a year ago and didn’t interfere with the job. I also took the opportunity to change the boot light to an LED bulb.
Hello, what is the name of the material you used to cover the trunk pool?
I’m afraid I didn’t do it. I had the audio system professionally installed and they took it upon themselves to fit the carpet to the boot as part of the job. I will see if I can find it though.
Edit: it’s likely this - or very similar:
Reactions: mhmtlii
I wrote all the below for a different thread but as it relates to this one I’ve also copied it here:
This is my description of fitting the rear brace to the i20N. It’s actually not so much about the fitting itself, as that is covered by the instructions that come with the brace and it’s all pretty easy. Instead, this is mainly a description of removing the trim needed to install the brace as that isn’t described in the instructions and is a more elaborate process than actually fitting the brace 😆.
To attach the brace to the chassis of the car you have to remove the plastic side trims that are inside the boot. Note that mine is a non Bose car but it’s essentially the same. Also, my boot has carpet but that is because it was fitted by my audio installer and is not standard. Ignore all the audio stuff in the spare wheel well as it’s not relevant to any of this.
So, removing these side trim panels isn’t hard but it is a bit involved. Each side panel is one big piece and goes right down to the back seat door tread. Because of this it makes life a lot easier if you remove the seat backs from the rear seats - well, you don’t remove them, just moving them out of the way is enough. To disconnect the seat backs you lower them and that allows access to the bolts #3. Where #1 is there is a ‘roll over clip‘ - flip that open. Then you can just lift the seats out of the slots where #2 is. Note, don’t get the seatbelts confused and tangled as this can make it confusing when putting everything back.
Next you will remove the trim bit #4. This is held on by two pull out clips - the kind where you pull out the middle button. Removing this is very easy.
Now you have done everything except removing the side panels. These are entirely held in by clips and just two screws #5 on the picture. remove the screws and then, grasping the trim near the boot, give it a good tug and start to unclip it - gradually working toward the back doors. The clips are all quite tough and fit in slots in the trim. When I did this I didn’t bend or break any of the clips. A couple came out of the side trim but they just popped back into place.
From there on it’s a question of following the instructions. Fitting the rivnuts was easy enough and provided an extremely secure fitting. The round hole that it is suggested to make in the boot trim is the absolute minimum and you might want to make a slightly bigger hole by a couple of millimetres. Also, if you find the side brackets for the brace do not line up with the holes then try turning the brackets over and also loosening the attaching bolts a bit to allow you to ‘wiggle’ the bracket a bit. Once you are happy then bolt the brackets up tight and refit all the trim in the opposite order you removed it. Finally you can attach the brace bar and that just bolts into place with the supplied hardware. You can adjust its length but I didn’t need to.
I hope that helps 👍.
After writing the above a couple of notes occurred to me:
All the plastics you remove are tough and have good flex - they aren’t brittle and it’s very unlikely you will break anything.
You could do all of the work on your own but I persuaded my good friend Dave to help me and this did make the job easier (and more fun). In total I think it took about three hours - if we were to do it again it would be more like two.
I had to adjust the shape of the holes I made in the trim, instead of just a circle think of a circle with the bottom cut into a square - I did this with a sharp craft knife and the plastic is easy enough to cut.
Everything went back together perfectly and nothing was damaged or compromised in the fitting.
The brace hasn’t led to any rattles or other noises and has been problem free.
Oh, I seem to remember something about also unbolting the anchoring points for the rear seatbelts - but I can’t remember exactly so probably my friend Dave did that bit!
Enjoy 👍😁
I bought some decals off aliexpress for mine - had them on my previous N and now on current, these are available in white or black
100_3074 by Rob H, on Flickr
Reactions: YNWaN
Oh, you’ve also had your wheels repainted in gloss black too - very nice 👍
Reactions: RME1987
That was the previous silver N - previous owner had them done in black - wasn't a fan tbh, keep debating if i should get the matt grey wheels lacquered for a gloss finish as they look nice when wet 🤔
Reactions: YNWaN
If you like them shiny get some compound polish.
I had a tiny mark on one of mine and used a bit of compound polish on it. (Menzerna 400) Where I polished to get the mark out, made it shiny, I wouldn't say it was lacquer shiny but was defiantly noticeable.
