So the gap on both cables is now the same?Ok so update to my 6th gear issue:
After lots and lots and lots of driving I finally had the issue again. This was expected; afterall we did not change the gear linkage cable towards the back of the car (that cable is responsible for vertical shifter movement). So I went ahead and set the same gap as I did on the front-cable: 1.85mm (aka the thickness of a two pence coin (don't ask me how, but @WoLf130 had one at home)). Right of the bat the 2nd, 4th and 6th gear felt smoother, so I am now hoping this solved the issue longterm. Keep in mind these measures are with the Forge short shifter installed.
Regarding the fix without installing the Forge short shifter: Corona is currently blocking us to try it on the other car. Will update you guys when we adjusted the cables.
As I understand it the lh cable is for sideways movement and the rh one is for fire and aft movement. That's looking from the front of the vehicle.
It is possible to have a nice smooth gearchange on the N mine is perfect in every gear so there is no reason why yours shouldn't be after the fix, though why some are good and others like yours bad is a bit of a mystery I would love to know what they did differently with mine that makes it different to yours because it shows they can get it right whether it's the parts that are defective or the assembly process who knows.Ok so 1-2nd and 5-6th gears didnt work properly with my car when changing gears. About 2 months ago phoned to dealer and said i had problems with 2nd, 5th and 6th gears going in smoothly everytime. They said they will ask about the problem with hyundai. Then the dealer wanted to test drive it so they could diagnose the problem. They had the same problems i had complained about and they ordered new syncros etc for the gearbox. Let see if it will get fixed after the maintenance booked next month. Now i will get my first test of how good the guarantee truly is. Will post more after the fix is done.
Must admit after reading various tales of woe about the gearbox it just does not seem possible they are talking about the car I drive but they are and frankly it's baffling, some on here maybe are being a little fussy in what they expect but it can't be all of them, has anybody come up with the definitive answer? as I have heard at least 3 different solutions that have been tried. Hyundai just seem to try changing different parts as if they have no idea either.Made even more confusing by the fact that some folks gear boxes start of rubbish (like mine) and now after little more than 1,500 miles it's like I'm driving a totally different car!
Fair enough, there's the age old comment about it getting better with age (rather like wine). But I've had many, many cars in some 40+ years of driving and I've never had one with a gear box that starts off this bad and it's character changes so quickly!
If it was an early QA problem, or bad batch of gear boxes etc... then you would have thought later cars would be OK. But mine is an MY20 (and "yes" I have checked the build date to conform this).
Weird...
No sir, there is no definitive answer. There is no definitive "car" as such. Further, this is not a Merc or a Beemer or some such (and even they have random issues). It is a machine built by humans and robots designed by humans so no two will be alike. Thus we all go round in circles. Still.Must admit after reading various tales of woe about the gearbox it just does not seem possible they are talking about the car I drive but they are and frankly it's baffling, some on here maybe are being a little fussy in what they expect but it can't be all of them, has anybody come up with the definitive answer? as I have heard at least 3 different solutions that have been tried. Hyundai just seem to try changing different parts as if they have no idea either.
Installed my short shifter today and have given it a brief test drive. I removed the airbox as well as the ECU and battery and tray to give the best access. I originally set the pins to halfway in their slots and tested it beofre replacing everything, I'm glad I did ad the side to side was much too stiff for my liking, I removed that part and moved the pin to about 3mm from the end furthest away from the spline but not as long as the stock distance, sis to side was now much better. Loosening anf tightening the securing bolts on the spine was interesting, I ended up using a 4mm Allen key in the two holes in the S shaped linkage which meant I could jam it up against the gear box whilst tightening and loosening the nuts. First impressions are good, got a decent run tomorros to a customer and it's all cross country so will report back again.
I didn't alter the cable lengths at all, thought I would suck it and see.
(...) things I've noticed, twice now it hasn't gone into first cleanly, i.e. you think it's in but it actually isn't.
That will be my next step if I'm not happy after acclimatising to it.You may be able to get rid of the problem by changing the length of the shifter cables. Just pull back the bit with the spring and push up the part inside a bit, then you can adjust the length freely.
So the jury's still out, will report back in a week.
try to stick to the adjustment method I posted here: https://n-cars.net/forums/threads/issues-with-5th-6th-gear.131/page-20#post-79740 (second pic)That will be my next step if I'm not happy after acclimatising to it.
I wish there was a documented adjustment method.
I'll do that. Thanks.try to stick to the adjustment method I posted here: https://n-cars.net/forums/threads/issues-with-5th-6th-gear.131/page-20#post-79740 (second pic)
That's the recommendation from Forge. I adjusted both shifter cables to have a gap of about 1.85mm - for me this solved the issues.
Got around to adjusting the shift cables this evening, also a chance to get the battery felt cover the correct way round, it has an arrow which needs to point up and sits at the front, I had mine back to front.
Anyway I measured the gaps before adjusting them, the side to side cable had 10mm and the front to rear had 3.5mm.
To adjust, pull back on the spring and using a fingernail under the bellows side of the cable hook the pink clip upwards, you can then slide it easily. I used the 2 pence coin trick and adjusted both to 1.85 mm, reassembled and tested, much nicer change now, had a blast on our deserted roads and it was lovely, no issues slotting into any gear at all.
The nicest thing about the shifter is it's adjustability, just slacken off the post and slide it up or down to suit. Only took an hour start to finish and no need to remove the airbox at all, you can get the battery clamp off and on without major difficulty.
