Intermittent hard starting
my passenger side ground is okay but the battery one is higher than it should be ?
Those values are not bad at all for not doing anything. Now test them again when the car is heat soaked. More heat results in higher resistance.
Can you change your pics to not be attachments, please? That interface is so kludgy and annoying.
Will keep my multi meter handy next time I take her out for a hard drive. And any suggestions for making them attachments from a iPhone?
So dumbed down a bit my passenger side ground is okay but the battery one is higher than it should be ? Lol
I'm sorry, yes as the heat rises in the engine compartment so will resistance. It can rise as much as 7.0-10.0 ohms. However as Cygnus stated; your grounds aren't bad. 5.0 ohms or less cold & clean is recommended for earth grounds. Autos are a little different.
I know in reciprocating engines (aircraft), they can rise as much as 25.0+ ohms. This is why they required a pyrotechnic start assist sometimes. (blank 10 gauge shotgun shells)
Not enough battery power to turn over the engines because of voltage loss. Batteries cables on; C-118's & C-119's, were as big around as your wrist. Still didn't compensate for the loss or impedance.
Reactions: Y0UKN0WITSCHRIS
I'm sorry, yes as the heat rises in the engine compartment so will resistance. It can rise as much as 7.0-10.0 ohms. However your grounds aren't bad when cold. 5.0 ohms or less cold & clean.
Not enough battery power to turn over the engines because of voltage loss. Batteries cables on a C-118's & C-119's, were as big around as your wrist. Still didn't compensate for the loss.
Wow I never knew any of that about planes that’s crazy ! Will retest them when warmed up a bit. Should I remove battery cables when I test it after it’s heat soaked ? Or just run it hard, pull over and test the points.
Also after finally testing these points and seeing they’re not as bad as expected. Can we determine they may not be the cause of the hard starts ? Tests were taken on a completely cold car that hadn’t been driven in a few days.
I can say every little bit helps. It may not solve the problem by itself but will definately assist in correcting it. There is another little device called; starter motor and solenoid. You have electrical connections running here as well.
If the starter solenoid gets very hot, it will cause a starting problem as well. A starter heat shield comes in handy. Something else to look closely at.
Heat soak causes all of these problems. This might be part of the issues as well. It all has to do with the electrical systems, impedance and resistance.
https://designengineering.com/starter-shield-ultra-47-series/
Happened a lot with hotrod V-8's, all my life. With this little motor and the aerodynamics of now, we may just be seeing another resurgence of the same thing.
Oh and this company has pipe insulation, turbo shields, Co2 cooling and more. that can help with heat soak as well. Just use the drop down list and book mark the website.
Deleted coz it was superfluous- didn’t see the third page of posts!
Sorry.
Just got a beautiful 2020 Racing Red N Performance Pack in stock today and guess what.. one of the sales guys got in it to try and move it and it cranked for a solid 5-6secs before it reluctantly turned over. Guess Hyundai still hasn’t fixed the hard start issue.
You guys had an infinity 8 speaker audio system with subwoofer in your previous models too? Here in germany we only get the standard 6 speaker without subwoofer in our i30Ns.
Same here in Oz. And we have to get down on our knees and beg / rudely demand that N floor mats and a full tank of gas be thrown in to the deal :rolleyes:
I don't see why Hyundai decided not to add it to the the i30N?? It's not like the stereo isn't available.
I suppose it's cost cutting to meet a price point? I know there are inconsistencies from dealer to dealer even country to country.
In the UK we get no options, like panoramic sunroof or upgraded stereo, I don't see why you wouldn't even offer them as options, plenty of people would have ordered them and that's more money for Hyundai?!
Same here. No sunroof, leather or heated seats. But we get a nice radio, push button start and auto climate control. So I’m not complaining
