Markus investigated the i30N failures in depth and also looked for possible solutions. Other N tuners hinted at the VN gearbox innards as a potential upgrade to the i30N. He bought a VN gearbox and disassembled it, finding the mentioned differences.Just curious; you said Markus indicated “the i30N is totally different from the VN and EN.” Being that neither is sold in Europe, how did he come to this conclusion?
Not sure I get your question. If you mean whether the SMF was in spec, then yes. All of the SMFs he put in the cars at the time were on spec and went under a quality inspection before they went in the car and also when he removed them later on as well.Did he indicate if the SMF within tolerances required, without any runout?
yep, this is also the thing which Markus said he did not fully understand. Some of the gearbox experts hinted to the failed coating of the second synchronizer being different to the coating of the other ones, but I am afraid I don't have further details on this.I’m a bit confused as to why, just the second gear synchronizer failed and others didn’t. The same vibrations are transmitted thru the entire gear cluster and housing. So, all will be subject to the same vibrations.
Generally when one synchronizer fails, the others will in sequence fail. In my experience, it’s a rarity for just one to fail unless that specific synchronizer is faulty, flawed or simply poorly manufactured.![]()
Appreciate the response and follow up!Not sure I get your question. If you mean whether the SMF was in spec, then yes. All of the SMFs he put in the cars at the time were on spec and went under a quality inspection before they went in the car and also when he removed them later on as well.
there is no such thing as the best clutch. depends on what you are looking for.soo whats the best clutch you can get on the market?
im still running the OEM clutch with a stage2 tune
i agree but i mean everyone is looking for a better performance clutchthere is no such thing as the best clutch. depends on what you are looking for.
but what are you fine to sacrifice for a better clutch? what max torque rating are you looking for - are you planning to stay with a simple stage2 tune or are you looking for more performance?i agree but i mean everyone is looking for a better performance clutch![]()
Best clutch for a stage 2but what are you fine to sacrifice for a better clutch? what max torque rating are you looking for - are you planning to stay with a simple stage2 tune or are you looking for more performance?
you cant just ask for the best clutch and provide no info what you are looking for![]()
