Tuning i20N Engine & ECU Tuning Discussion
Is this stage one? Are these colder plugs than oem? Does KLASEN recommend them?
As I think the gearbox of the i20N seems not very strong to me and does a lousy shifting task to me I wonder how long it will keepbup to a tune. I have to mention that before this car I had already four tuned cars. So I’ really into it but I don’t dare to do it to my i20N because of the gearbox. And I have no idea if I have reason to doubt about it…
Have you changed the oil in it yet? The oil also lubricates the LSD and after I saw reports of the oil being dirty after 10,000km I had mine changed at 16,000km and it was filthy. I used Penrite Pro Gear 70W-75 full synthetic and the shift has been really decent.
Why do you think the i20N gearbox is weak? I’ve had no problems with mine and the shifts are consistent and precise irrespective of load and my car is heavily tuned with a hybrid turbo etc.
Changed it allready 4 times in four years. First time I had some very dirty oil in it but no metal parts! Then I changed it again few thousand kilometers later and clear oil without metal parts. Now I change it every year before winter. Next time in a few weeks. At the moment I have Red Line mt-lv 70-75W gl-4 high performance for manual transmission.
Still it suffers from being difficult to take the reverse in the morning when cold oil. And still crappy shifting from second to third…
Also, I do have the feeling the lsd doesn’t work every time… on my daily route to word I take the same corner and sometimes the car really understeers and other times it corners very well and I could have taken it at a higher speed. So not much confidence…
Hyundai dealer doesn’t feel much, they say everything works fine.
Maybe my car is trying to tell me something…
Mine is super slick cold and goes through a mid warm up point where it can be a bit hesitant into 3rd but that goes away warmed up. Compared to an ND MX-5 I had it's a dream and the GT86 was a pain too, that got a new gearbox under warranty. I don't need to use reverse cold but i'll try it next time. Everything that i've seen suggests the gearbox is strong as is the engine.
Maybe I should try the Penrite oil as well. I’ll have to look up if it’s available here. But it’s worth to try an the gearbox oil change isn’t difficult to do
It's an Australian company so I doubt it's available but trying a different brand of oil sounds a good idea. What was it like before you changed the oil? Another factor could be in the cable adjustment. The clutch isn't engaging low in the pedal travel?
They changed the oil at the dealer for me during the service and only charged AU$35.
Clutch finetuned by Hyundai dealer. But I started changing the oil because of the lousy shifting. When new oil applied it feels like it shifts a bit better burnout for long, so I think it’s imaginary…
I will replace the oil in a few weeks, and now I found a specialist here who I think I’ll have to consult to diagnose if it stays like this.
Most common issue is the engaging of the reverse. But the biggest problem is when shifting fast from second to third in all the drive modes. I’m a bit worried about the synchro meschanism…
If the clutch pedal travel floor to fully released is 0-100 where does yours start biting to fully engaged? Mine is about 40-60. Have you tried selecting 1st gear before reverse to align the gears when it doesn't want to go in?
If the cable adjustment is wrong then it can effect other gears. The fact that you are having issues with reverse and 3rd suggests it could be the cables, especially if 1st and 5th are sometimes tricky but 2nd, 4th and 6th are alright.
I have an engineering background and can never understand how people can rip through the gears without the mechanical sympathy for what is being asked of the gearbox and clutch. My uncle learned to drive late in life and literally ripped through the gears as fast as he could to get it over with. It was scary.
Clutch start grip 30-40%. Works perfectly smooth. No noises as well.
Start with first gear and then reverse is sometimes the only sollution.
First and fifth always smooth. No problem with the other gears only fats to third and on a colder morning reverse.
I changed my gear oil to redline as mine felt notchy going in to 3rd and 4th reverse is fine, didn't make any difference. I don't force my changes and I'm very sympathetic. Thing is it doesn't do it on every shift. Car is going in to garage in November and I'm changing back to factory oil. I'm also going to get the shift cables adjusted. Its the same procedure as the i30n as far as I'm aware.
Reactions: JoKiV
Okay, well that’s all great but it’s just a statement - let’s see some evidence, I want to see dyno results.
